Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
Profiles and symmetric airfoils
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 08-01-2005, 12:31 AM
Pubhi
Default Profiles and symmetric airfoils
I was just wondering why profiles and so many 3d/aerobatic aircraft use symmetric airfoils? What advantage does a symmetric airfoil offer over a more conventional flat bottom or semi-symmetric?
Old 08-01-2005, 06:21 AM
65 Chevy
Default RE: Profiles and symmetric airfoils
Thats easy. Semetrical airfoils provide nearly equal lift when right side up and inverted. Profile and 3D planes usually have a fairly thick airfoil also which allows them to have more liftat similar speeds or the same lift at lower speeds as compared to a thinner wing profile. A thicker airfoil also hhelps keep the plane from building so much speed in a dive or on the down lines of manoevers
Old 08-01-2005, 07:30 AM
Ed_Moorman
Ed_Moorman's Avatar
On any type of power plane, you will probably find that a symmetric airfoil flies best. Flat bottom airfoils in particulat and semi-symmetric to a certain extent, are very pitch sensitive to power/air speed changes. You can use down thrust, change stab incidence or use a slightly lifting stab, but the most pleasurable flying airfoil, to me, is the symmetric. At any power setting I am not messing with the elevator trim to keep the plane from climbing or diving.
99% of our models are way over powered compared to a full scale. This gives us a wider speed range which complicates the pitch trim. A symetric airfoil gives you less changes.
