retract air line to brake line reducer
10-20-2004, 08:38 AM
NY
guys
i am installing a jet tronic brake valve in a jet
where can i get a reducer to connect the retract size air line
to brake size airline
thanks
vinny
10-20-2004, 08:42 AM
RE: retract air line to brake line reducer
I've always used the same size tubing on both retracts and brakes.
10-20-2004, 08:51 AM
NY
Vinny the jettronic is 3mm line, what are you using on the brakes ? Are you using the small clear BVM line ?
Don
10-20-2004, 12:29 PM
NY
don
yes i am using the jettronic brake valve with bvm brakes
need to go from the 3mm to clear bvm line
vinny
gary can i change the brake fitting on bvm brakes to retract air line size
thanks
vinny
10-20-2004, 12:41 PM
I found that the easiest solution is just to use a barbed straight-through fitting to join the two pieces of line together.
10-20-2004, 12:46 PM
I couldn't find any straight thru air fittings that small, so I drilled through a pair of Robart air line restrictors with a number drill that just fit the open side of the fitting.
10-20-2004, 04:54 PM
NY
gary
i had some old brass restictors
drilled the hole out works great
thanks for tip
vinny
10-21-2004, 12:19 PM
i got 2 fittings with my [euro kit ]gear that go from festo line to small brake line......you might check with the [euro kit] folks if thats what you need.
