Servo Hitec HS-5645MG,receptor airtronics question !!!
Hi friends... have the servo Hitec HS-5645MG Digital Ultra Toque
Reading the manual says,
Special Warning for Digital servos !!!
(1) If you accidentally plug in the Hitec "S" type digital servo into the old Airtronics(Sanwa) receiver, this will blow up the servo circuits so please take special care.
(2) Digital servos consume tremendous amount of power, so dry batteries cannot be used at all. Use large capacity Nicd batteries or better yet NiMH batteries.
(3) Do not use BEC system built in most 2 channel receivers. Make sure you bypass the BEC for stable operation.
I have this receiver: Airtronics 92721 2 Channels (Sanwa) BEC ....
If I switch the servo to this receptor is damaged?
That receiver and control, I recommend that you purchase?
Thank you and greetings!
