Help Me Build The Best AX10
Dear All,
Help is Needed. Plz do write in as much as possible regarding the Context, Build the Best AX10. I live in Pakistan & have No Local Hobby Shop, so where do I get My stuffs from, Sigh...... HobbyTown Dallas, thats My LHS
I can't get the stuff again & again from U.S, so I want to build the Best AX10 Out there. Something very Reliable & Durable.
Let Me know what other Chassis should I Use, what ESC, What Motor, What Axles, What Tires & the List goes on & On.
Thanks EveryOne in Advance,
Regards To All,
Haris Khoso.
Regards To All,
Haris Khoso.
RE: Help Me Build The Best AX10
Here are my suggestions:
Axial AX10 Scorpion Rock Crawler ARTR or start from the ground up
Tekin FXR ESC Crawler Combo 35T Motor TEKTT2106
Bender Customs SWX Chassis Kit
Scorpion Bender Customs 4 Link Plate AX30507
Low CG Battery Plate
STRC Aluminum C Hub Carrier Black (total of 4)
MIP Steel Center Drive Shafts 08101
STRC Aluminum Steering Knuckles
Stainless Steel Outdrive Shafts
Panther Cougar Tires (4)
I either have these on my crawler and recommend them or I want these for my crawler.
Good Luck!
Jason
Good Luck!
Jason
Also, you might want to look through the tips on this link:
http://www.rccrawler.com/forum/showthread.php?t=152038
