Alternative to spot putty?
Does anyone know of an alternative filler on fibreglass or wood surfaces which spreads as easy as spot putty but doesn't have the affects on the nervous system (darn, there's that twitch again).
Jim
Jim
RE: Alternative to spot putty?
i've been using evercoat but i don't think that will help you. what about superfil? i researched it but settled on evercoat due to being available locally. are you using this on raw balsa? i have seen threads where builders use lightweight drywall mud to skim the entire fuse. it was sanded off until only the flaws were filled. apparently the resin bleeding through during the fiberglass application soaks into the mud and hardens it.
i've also tried watering down the lightweight balsa filler and painting my fuse with it; of course sanding it off after drying but that won't fix bigger flaws.
david
david
Hi David, it's the consistency of the light weight balsa fillers I'm not happy with. I've tried watering it down to help. Sometimes I use DAP coloured light splacking (changes colour as it dries). I was informed from a local napa store that the Canadian government has restricted the retail sale of spot putty. It's availability is to auto body shops. Most likely trying to protect the public use by individuals which might not have proper safety equipment. I'm using the spot putty to fill some epoxy glass reinforcement on a model. It goes on heavy but I'll sand 98% of it off the surface.
Jim
Jim
My Feedback: (42)
Elmer's Carpenter's Wood Filler works great for me. http://www.redhillgeneralstore.com/A40266.htm
Thin with water to the consistency of ketchup before applying.
Much better than the latex based "lightweight" fillers.
This product reportedly works well for filling pinholes in fiberglass. (I haven't had a chance to try this yet)
http://www.darrolcady.com/Accessorie...nting_faq.html
I would not recommend using automotive spot putty on bare wood. (Dries too hard, toxic solvents)
Elmer's carpenter wood filler is readily available from Rona or Home Depot. It's inexpensive, I'll have to give this a try. I think I might have some at home. Maybe I didn't try watering it down enough.
Jim
Jim
I don't water it down, although sometimes it may need a few drops of water to loosen it up a little.
Something that is nice is that because it IS water soluable, after applying it you can smooth it out with a wet finger.
Take a look at my most recent use of it:
http://www.rcuniverse.com/forum/fb.asp?m=8045758
MN
Superfill works great (from aircraft spruce), however, it takes a long time to dry. Evercoat works well also, dries to a sandable form in under 20 minutes, but is expensive, and heavy. I like the bondo glazing putty (red stuff), works well, easy to shape with a wet finger, and sands nice. Never had any luck with the light weight spackels, plus it falls out of fiberglass pinholes when wetsanding the primer...
How quick does the Elmers wood putty dry? and does it work on fiberglasss?
Dave, I've never used it on Fiber Glass, so I can't say.
as for drying time, like anything it depends on how thick it's laid and temp/humidity, but the Fillets in this pic dried completely over night:
Thin applications are dry in about 1/2 hour
ORIGINAL: daven
I'll probably try the Elmer's on a different project (it's only half as toxic).
Maybe some of the hobby manufacturers can work on some new putty material which applies like icing, environmentaly friendly and not toxic to my health. Don't expect to get this from China though.
I found my container of Minwax Wood Filler. Scooped out a couple of teaspoons and diluted it down to a much more workable paste. I think this will work. Have to remember this for the next model.
Thanks guys.
Thanks guys.
ORIGINAL: martyg
MinnFlyer, you should try the MinWax it comes in different favors ... I mean colors. Try maple.
ORIGINAL: MinnFlyer
Half as toxic? Hell, I put that stuff on my cereal in the morning
ORIGINAL: Jim_Purcha
I use drywall compound. It sands as soft as balsa and is as cheap as it gets. For filling pinholes in glass surfaces I get a wet blob on my fingers and rub it in. Let it dry and sand it flush. It can be sanded only dry.
Ed S
Ed S
i've seen the opposite where users of evercoat claim the bondo spot putty is too heavy. i have both. i use the evercoat for larger areas before glass and the spot putty after glassing.
david
david
As far as weight is concerned, I used to be weight conscious too, so I tried some of those light-weight spackle compounds when they first hit the market. But when I saw that the heat from my covering iron was melting them, I went back to Elmer's.
The way I see it is: if you use so much filler that weight becomes a problem, you need to work on becoming a better builder
MN
I suppose I should read the tube of glazing putty, thanks for the warning. I guess it will be a glove next time. Both the Evercoat and Bondo are heavy, when I'm doing something large its going to be the Super-Fil, really neat stuff and light.
My Feedback: (10)
One of the guys at my club recommended using the lightweight spackle, you know...the stuff for home owners that can't do drywall finishing. Much lighter than regular spackle and sands easily. It dents a little easily, but so does balsa.
ORIGINAL: wannabflyboy
As I have said before, if you use so much filler that weight becomes an issue, you need to improve your building techniques.
My Feedback: (10)
ORIGINAL: MinnFlyer
It also melts under the heat of a covering iron. I recommend that people avoid this stuff.
Not trying to start one of those "forum battles", but the stuff I'm talking about is water based and will not melt.
I agree that if you use enough filler that weight is is a problem then you need to look at your building skills, but anywhere weight can be saved is a bonus to me.
