2 speed tran for NTC3?
is it easy to change to a 2 speed tran yourself? i bought the 2 speed tran kit, but im not sure if i want to do it myself. only cost me $39.99 for the 2 speed tran kit.
it is very simple - i have the kit - which u build yourself and already comes with the 2 speed - just follow the directions - if u can tie ur shoes, then u can install the 2 speed. just pay VERY CLOSE attention when u install the set up screws, make sure you do it just like it says, otherwise u will have trouble shifting - congrats on getting the greatest touring car alive!
speed is revelant to the engine you have, and how you have it tuned. but a two-speed tranny will generally give u about an 8-12mph increase. keep in mind that the major benifit is acceleration, not top speed, as u can use a much lower gear to get out of the hole. top speed means almost nothing on the race track, its all about handleing, braking, and acceleration
u can get the 2 speed tranny just about anywhere. Check with your LHS first to support them, if they dont stock it, you can get it at www.towerhobbies.com and also at www.rc10.com
2 speed tran for $40
the hobby shop local to me had the 2 speed tran for $39.99 along with the ntc3 rtr for $259.99 - a $10 coupon, so i decided to get both of them.
the hobby shop is located in covina, CA
Elite Hobbies
you are correct wild gopher, that is the hobby shop i got it from. I bought both my ntc3 rtr and my nitro rustler 2.5 from them. Pretty good hobby shop, its only about 15-20 minutes from my work. Do you buy stuff from elite, wild gopher? Also where is the best place to take your street car to race? other than revrace.com, since I see you live in pomona.
