Blue threadlock
Old 07-06-2008, 05:52 PM
kenali
kenali's Avatar
Default Blue threadlock
I still have about half of bottle left but I noticed that it doesn't work very well now, seem like no matter how clean is my screws is when I applyed on my engine mount screws is always got loose it up after about three to four tanks then I end up stripped my spur gear, is it true that blue threadlock can't stay long after the first used??
Old 07-06-2008, 05:54 PM
superman11
superman11's Avatar
Default RE: Blue threadlock
Sounds like it is an old tube... Try getting a new bottle...
Old 07-06-2008, 06:46 PM
RCCanuck
and are you letting it set for 24 hrs before use,,,,,I noticed that the older it gets the longer you have to wait for it to set.
Old 07-06-2008, 06:48 PM
StemTMAXX
I use Blue Thread Lock and it holds like a charm. no loose or lost screws since I started using it.
Old 07-06-2008, 09:01 PM
Mspeed
Get the paste type of blue loctite. Its much easier to handle. You must have alot of stuff modified on your Tmaxx? It is a Tmaxx? Alot of metal or alum. can sometimes cause more vibration to transmit and start knocking screws loose. Usually traxxas does a better job than some of the other companys when it comes to keeping their screws from coming loose. If you cant fix the problem, get the red locitite and only use it were you have to and be very careful its hard to get the screws back out without breaking them.
Old 07-06-2008, 09:33 PM
kenali
kenali's Avatar
I don't know how long is consider is old? I bought this bottle last April, this bottle use to be used in my helicopter now on my rc car. Modification?? Yeah... but all those modification just the normal stuff! Anyways, thanks for all your help here and I'll get a new bottle and see if this will solve all the problem =)
Old 07-06-2008, 09:40 PM
Mspeed
ORIGINAL: kenali
I dont usually see problems with the stock traxxas screws coming out with all stock stuff? Thats why I said modifications.
Old 07-06-2008, 11:38 PM
bob5429
aluminum is a metal Mspeed[&:]
Old 07-07-2008, 12:24 AM
Sparco
Sparco's Avatar
ORIGINAL: bob5429
not all metal on a truck is alum (usually)
Old 07-07-2008, 08:25 AM
Anomie
Anomie's Avatar
Sometimes the liquid can separate when sitting on a shelf for long periods (months). You can try removing the cap and stirring and then shake the bottle after closing it again. It may help a bit.
Old 07-07-2008, 10:52 AM
warheadforever
warheadforever's Avatar
I have never noticed this, but then again I get the really high quality stuff.
Old 07-07-2008, 08:20 PM
kenali
kenali's Avatar
ORIGINAL: warheadforever
Can you tell me what "high quality stuff" is? Do you mean the threadlocker right or sopmething else??
Old 07-08-2008, 10:24 AM
warheadforever
ORIGINAL: kenali
Here you are.
http://www.amazon.com/LOCTITE-Thread.../dp/B000NZZY9O
Old 07-08-2008, 11:54 AM
kenali
kenali's Avatar
WOW... that is expensive stuff, but is red threadlocker basicly is permanent threadlocker.
Old 07-08-2008, 12:02 PM
warheadforever
ORIGINAL: kenali
No, you just heat it up a bit, and it come right out. But is is expensive.
