Monokote Trim Solvent
Old 09-17-2003, 03:48 PM
scole
Default Monokote Trim Solvent
I have used monokote as a trim color and ultracoat as a base, will the trim solvent work on keeping the monokote on?
Old 09-17-2003, 05:31 PM
Stripes
My Feedback: (19)
Default RE: Monokote Trim Solvent
Oh, it works great. Sticks fine, but can give eratic results. The stuff disolves the adhesive backing which also contains the color. Leads to eratic color results. Use with caution.
Old 09-23-2003, 02:30 PM
DGrant
DGrant's Avatar
Why dont you just add a little heat, then it won't go anywhere.
Old 09-23-2003, 10:17 PM
Combat Addict
Combat Addict's Avatar
I would just Iron it on. That would work better. I think
Old 09-23-2003, 10:28 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Why not use the windex method, then go over the edges with low heat or trim solvent ? Do a search under windex and you'll find plenty of greta info. Professional results that last.....
Old 09-24-2003, 06:45 PM
scole
Thats what i did, except it doesn't seal the edges very well at all. I used some acitone around the edges and it held in place.
Old 09-24-2003, 07:13 PM
rajul
Moderator
My Feedback: (58)
rajul's Avatar
Hi scole, I think the TF trim solvent is mostly acetone. You don't need much to seal the edges. If you can see it, its too much.
