someone gave me this car
Old 01-23-2007, 08:46 PM
gregbuzzsteve
Default someone gave me this car
someone gave this car and i need some help . i dont know anything about it just know it runs on nitro has a pull start.
im not sure where to get info on it . i got it to start but it runs full throttle and i cant get the carb to adjust to make it idol
i kinda stuck at this point right now so can someone please help me out here
thanks for your help , Greg
Old 01-23-2007, 09:11 PM
ASSOCIATED_DRIVER
ASSOCIATED_DRIVER's Avatar
Default RE: someone gave me this car
Post some pictures so we can identify the rc.
There is an idle adjustment screw just below the throttle opening (below the airfilter neck). There should be a 1 mm minimum opening on the carb, even when brakes applied. It should not close.
Old 01-23-2007, 10:16 PM
gregbuzzsteve
i think this car is a savage if that helps
Old 01-23-2007, 10:18 PM
hands without shadows
hands without shadows's Avatar
Does it look like this?
Old 01-23-2007, 10:30 PM
gregbuzzsteve
yeah thats it [8D]
Old 01-23-2007, 10:35 PM
running_gag
Now we're cooking. I suggest going to HPI's website and down loading the manual for the savage. actually, not that I think about it there are like 4 or 5 different versions and I'm not qualified to figure out which one you have. www.hpiracing.com go check this out while someone who knows better can help you determine what species of beastie you have.
Old 01-23-2007, 10:56 PM
-EXTRA-
-EXTRA-'s Avatar
wow i wish i had a friend who would gimme a savage lol i think that friend is a keeper
Old 01-23-2007, 11:02 PM
46u
46u's Avatar
All Savages are basically the same and most parts are interchange able. The biggest changes have been in the new version the X. If it has the alloy roll bar it is the older version. Yes first thing is to down load the manual or get pictures to help tell what Savage it is which is sometime hard to do. I have a Savage with well over 7 gallons or run time on it and it has been a great truck.
Old 01-24-2007, 08:42 PM
nitro _ burner
nitro _ burner's Avatar
yeh download the manual or u can remove the airfilter and you will find a hole with a wall that slides open as you open the carby. find a screw that adjusts this wall so it leaves about a 1mm or 1/16th gap for the air to get through.
