Help wanted with Powerbox
I have a powerbox 40/24 and I am trying to set up my flaps using a JR 9 TX. The instructions ask for the end points to be set up first by confirming the neutral and full up and down positions. This works Ok for the controls using the sticks but where do I start when using the flap switch? Do I use the neutral position as the mid flap position? I have now totally lost movement on my DS8511 sevo and cannot get it to move. Any help appreciated I,ve lost the plot with this one!!
John
John
RE: Help wanted with Powerbox
All I can tell you is to go into function mode and reset the TX for that model. Reset all data to 0. Start over if you can't even get the servo to move anymore.
