140L
140L
Hi Dave.
I have a 140L that vibrated the screws loose that hold in the cam shaft bearing , it resulted in the teeth of the camshaft getting broke off.
I have a camshaft from a spare 140L but I would like to know how to set the timing again? , there is a pip on the crankshaft and a pip on the camshaft , the pip on the crankshaft is nearly pointing down when piston is TDC
also will I have to strip down engine to chck for metal particles?
Thanks for your help,
John
John
RE: 140L
With the psiton at TDC, the punch mark on the side of the cam gear goes straight UP. I would take this engine apart and check it for chips before running it again.
RE: 140L
Thanks Dave but 1 last thing , when u say the pip on camshaft goes UP , I assume you mean Up the same direction as the piston?
Also Dave is the tappet gap .003"?? and when do i set this , also at TDC?
Just to confirm , TDC is when the piston is fully UP , cos at that point the pip on crankshaft counterweight is NOT exactly pointing down.
Keep up the good work ,John
