Where do you hook the Brushless ESC on the Walkera #36 Rx
OK so
CH1 elevator
CH2 alieron
CH3 actiyator
CH4 empennage
CH5 gear
CH6 pitch size
so the only two that is left is CH 5 and CH3 which is it I am thinking CH3 but i am not sure so which is it
and also is it ok to take off the Motor and Battry wire out of the Rx
thak you
Dinuka
CH1 elevator
CH2 alieron
CH3 actiyator
CH4 empennage
CH5 gear
CH6 pitch size
thak you
Dinuka
RE: Where do you hook the Brushless ESC on the Walkera #36 Rx
Yes,
Channel 3 should have nothing it it. That is where you connect.
Normally there is nothing in channel 3 because the receiver also has the speed controller built in.
ORIGINAL: dinuka
OK so
CH1 elevator
CH2 alieron
CH3 actiyator
CH4 empennage
CH5 gear
CH6 pitch size
thak you
Dinuka
OK so
CH1 elevator
CH2 alieron
CH3 actiyator
CH4 empennage
CH5 gear
CH6 pitch size
thak you
Dinuka
OK, you unplug the battery and motor wires from the battery and motor, and just leave them.
The battery then plugs into the ESC, and the ESC plugs into the receiver.
That is how the receiver now gets it's power to operate.
DO NOT cut the old wires off the receiver, as one day you may want to return the helicopter to normal motor (to sell, or the ESC burns out, etc)
ORIGINAL: dinuka
What about the exsisting Motor and Battry wires on the Rx? can i take tham Off?
what you do is patch the +/- wires into the correct Rx batt wires (the ones that attach to the batt not any thing on the batt.) ok that done plug it into the 4 spot. there take that and plug in the motor and you have a brushless system.
