instructive direct drive main motor winding diagram pictures
Clear instructive pictures of direct drive main motor winding diagrams plus English text
http://www.powerditto.de/
-> English
-> (Tools) winding schemes in pictures
Vriendelijke groeten Ron
• diy motor building tips & tricks
• diy outrunner discussion group
• int. E fly-in & diy outrunner meet, June 25 2006, Nijmegen, the Netherlands
-> English
RE: instructive direct drive main motor winding diagram pictures
uhhh most cdrom drives are 12 pole.... wiring diagram is wrap one pole until full then skip two wrap, skip wrap then start with your next wire repeating. you can look here for the proper neodimum magnets: http://www.engconcepts.net/List_Of_Ring_Magnets.asp
cheap, good quality, and can be coustom ordered. just take 12 N50 , 5x5x1mm magnets placing them around the outer rim of the motor N/S/N/S spacing evenly and CAing them in place. there hook that up to your ESC and you got a brushless motor!,
On www.powerditto.de you'll find several direct drive helicopters.
[/ul][*]Made from a floppy disk drive motor
http://www.rcgroups.com/forums/showt...hreadid=197862
[*]A second direct drive motor, from two 5.25" floppy disk drives. Polish and German text:
http://alexrc.com/voytek_pl.html
Christian Lucas' direct drive helicopter, powered by a hydrogen fuel cell:[*]http://www.rcgroups.com/forums/showt...88#post1030688
[*]More do-it-yourself direct drive helicoptermotors
http://www.powerditto.de (in German & Englisch).
[*]And
http://www.torquemax.de/AndereMelber.htm
[/ul]
[*]And
[/ul]
Nice pics Thanks for posting.
I've used a direct drive brushless for the tail, when I made one up at 11grams once.
But the controllers I found really weren't suitable for the task.
But a complete direct drive heli - main also, would be a good idea And would be cheap if made in quantity.
David
David
as well as quality, how much does it cost for that upgrade? heh that looks really sweet as well as it looks like it has more power than it knows what to do with, equip that with belt drive, and unless you crashed you could haul until your blades snap. [>:]
PS: I enjoy that kind of thing.
well I meant how much do the parts cost? and where can you get them, this might be my next upgrade, but I already DO have a brushless motor.... oh well, guess I'll have to save up.
There are no parts available, that's how diy it is. You can however rewind floppy disk drive motors:
