PST J600R shutting down? What could cause this?
My Feedback: (34)
If I read correctly after auto shut down. There is a star next to the REV and indicating 24000. How could I adjust this??
Here is a pic of the GDT after shut down.
COuld it be I need to adjust the failsafe in the GDT?? and on TX?? DO I just bring the ATV Past 100% bind and bring back to 100% after rebinding?? and go through the failsafe setup on GDT??
My Feedback: (34)
In the Manual it says this message is either cases by low battery or sticky fuel pump. I recharged the battery after the starts and I only put in 500 mah on a 2500 size nicad battery. Will try running the pump for 10 mins like the manual says to see if it's the pump
NY
Jonny,
See my advice on the Reaction 54 thread. Back out the EGT probe a little ( 1/16th") and separate the start tube from the tail cone about a 1/2 to 3/4 "gap . Both items are causing the high temps and shutdown.
Rgds,
Art ARRO
Rgds,
Art ARRO
My Feedback: (34)
OK so here is the second attempt with the egt probe pulled out a bit. For some reason it never starts the first time. Lines were primed. And also took a little longer to start this time. But always starts second attempt. Video is still uploading. In this video you can see I ran full power a few times and taxied around a bit. Towards the end I attempted to go full throttle again and it quit..
https://www.youtube.com/watch?v=vOCpRX0_Zvo
My Feedback: (34)
Here is the start sequence with the EGT pulled back a little and start tube further back. I noticed EGT was a little higher not lower with EGT pulled back some. And took longer to start. Also as you can see. Could not start via TX again. went through learning RC and nothing.
https://www.youtube.com/watch?v=QmIbgz_DgUk
NY
Johnny,
The 2nd start issue is common with the EGT probe extended out of the tail cone. Some guys live with it but I'd move it back to its original position. What were the EGT readings at idle and full power with the extended EGT position? They should under 800C, preferably lower. You definitely do not want to have the turbine shutdown at full power, especially after takeoff. The failure to start 2nd time may be a function of turbine cool down. Most turbines won't restart unless the EGT is below 100C. You can use a blower to get the temps down quickly without engaging the starter motor. Also some turbines like to have the ECU power turned off before a restart. I know this is frustrating but you need to get it right before any flight attempts. Hopefully some PST "experts" will chime in here.
You also must have very forgiving neighbors in your street. Keep trying and let us know how it all goes.
Rgds,
Art ARRO
Rgds,
Art ARRO
My Feedback: (34)
I'm starting to lean towards weak pump. Hense why I ordered one. Gonna change the rev low and mid values to see if that helps with current pump. But first gonna fill tank and use the prime function to run the pump until the tank is emptied into a overflow tank and see if that helps the pump at all
NY
Johnny,
Some fuel pumps are a bit weak when new and need to be broken in a bit. Running a tankful into your overflow may help break it in. Does you TEMS display show a pump prime voltage when running. Sometimes this value will drop as the pump wears in. Document you current values before changing them to go back if need be.
Good luck.
Rgds,
Art ARRO .
Good luck.
Rgds,
Art ARRO .
NY
Johnny,
Unfortunate that PST Thailand does not respond. You might try to contact some of their US Reps. I believe they are listed on the website-if it is still up. Hopefully someone will respond. Another tack would be to attend the AMPS Rally and see if someone has specific experience with the PST 600R. I was in a similar situation with my RAM engines as they went out-of-business about a month after my purchase. I had to contact many users and finally found Carlos V. to be very helpful. Good luck.
Rgds,
Art ARRO
Rgds,
Art ARRO
NY
Johnny,
Go to PSTJETS.com and both Dean Wichman and Kelly Williams are listed for N. America Reps along with their contact info. Either should be able to resolve your problems. I downloaded the PST600R Manual and there is nothing unusual about this turbine. Note that PST recommends that the EGT probe must be inserted no greater than 2mm, into the tail cone. This is about 3/32" and you can check it with a piece of 3/32" balsa as a simple gauge. Also the manual lists the default parameters and these should be verified on your display unit.
Rgds,
Art ARRO
Rgds,
Art ARRO
My Feedback: (34)
Thanks Art I sent both those guys emails but the emails came back. I don't think they are reps any longer or the emails don't work. Bruce Tharpe is even a rep and also sent him an email. I will go through the paramaters again but this turbine has only 3 hours on it. It was last sent to Thailand in 2008 and they changed the parameters and I have a paper with the numbers they changed it to. It hasn't been run since till now. I will go through the ecu and write down what it's set at now. Compare to what they did if they jive and start playing with the ramp low and mid numbers to see if it helps. But another ex Rep Kelly seams to think there might be some clogged fuel ejectors. I was also told to blow some compressed air in the fuel inlet of the turbine to see it that opens up or loosens any particles that may be logged in the ejectors
My Feedback: (34)
This is what Kelly Williams ex rep said
So while idling, the turbine isn't really running too hard, so it should sustain ok. Now then, when its asked to accelerate, then the combustion needs to intensify to blow harder on the exhaust turbine and accelerate the shaft, which is a lot to ask for a turbine that's barely running. This is why all turbines ramp up slow from low rpm but crazy fast at any other speed...
If the combustion quality is low or unbalanced around the ring, a sudden influx of fuel can make it go rich, so now combustion takes longer. If that fuel is still burning as it goes past the turbine wheel, you have less pressure differential across the wheel, making less torque, making the shaft slow down when you asked it to go faster.........
If it continues to go slower, and fuel keeps ramping up, it'll just get slower and hotter...
Keĺly
Keĺly
NY
Johnny,
Looks like you're on the right track with the turbine. I have a "little blue book" that I compile all the operating parameters and conditions of my 4 turbines-sort of like a logbook. For the clogged fuel injectors- definitely a possibility, you can try looking into the tail cone using a large mirror and observing the flame pattern. The pattern should be equal around the edges and is sometimes better visible in near darkness. Blowing compressed air into the fuel port is also a possible fix but I'd due this as a last resort. Any air or liquid has to be really clean or you could introduce more clogging. It's too bad that PST doesn't have a viable rep network in the states. Actually, only 1 of my turbine brands has a US Rep- Jet Central- and I limp along with other operators that I trust.
Rgds,
Art ARRO
Rgds,
Art ARRO
