Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Monster Trucks > Traxxas Monster Truck forum
2.5 T-Maxx Best Transmission Upgrade For BB Power?
Old 03-20-2011, 11:50 PM
22TRunaway504
22TRunaway504's Avatar
Default 2.5 T-Maxx Best Transmission Upgrade For BB Power?
My 2.5TMaxx as a classic with .15that has been upgraded to the point that the onlyoriginal part's left intact are the Transmission,Diff's&Center Driveshafts.
That being said i'm lookingstepit upfrom 3.3 power to O.S..21to.25OR Picco .26 Max JL Rre Dot.
Something with wide ratio gearing allRobinson R.steel gear with diff's suited to handel anything.
Will a 3.3TMaxx Transmission/RobinsonR. Gearingbe the soluion and what modifications need to done
to the Tranyto beinstalled to my 2.54mm Traxxas chassie?
All input appreciatedThanks 22TRunaway504</p>
Old 03-21-2011, 05:18 AM
Snook Man
Snook Man's Avatar
Default RE: 2.5 T-Maxx Best Transmission Upgrade For BB Power?
<p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><font face="Times New Roman" size="3">The 3.3 tranny will mount directly to the 2.5 chassis. It has 2 different types of braking systems depending on which model. You will need the brake setup and appropriate center shafts.</font></p><p class="MsoNormal" style="MARGIN: 0in 0in 0pt"><font face="Times New Roman" size="3">When shimmed correctly the RRP gears are almost bulletproof.</font></p>
Old 03-21-2011, 11:07 AM
DEKUM510
I would try to find the 3.3 with the old style breaking system, same as the 2.5 I believe. To avoid headaches down the road with hardware compatibility.
If your getting the RRP kit for your max you need to buy a revo main output shaft for the transmission to make it fit in the max trans case. Part #5369 I believe. Ihave this kit in my tmaxx + jl red dot and it screams....shifts perfectly, no problems so far.
Old 03-23-2011, 10:28 AM
22TRunaway504
Snook Man, Thank's for the info.</p>
Just last week i swapped out my 3.3 engine foe a new one.And keep it as a back up after i buy whatever Big Block
I decide to go with but for now I'm going to hunting down atransmission&amp; part's needed to do this.
Thank's agane Snook. TRunaway</p>
</p>
</p>
</p>
</p>
</p>
Old 03-23-2011, 10:36 AM
22TRunaway504
DEKUM510, I'm just back with you to thank you for the info and taking the time and getting me the modle #.
Thank's agane, TRunaway
Old 03-23-2011, 11:36 AM
jake383
i have the 2.5 4910 truck, the best thing i did was put forward only trans, have had no issues and its cheap.....good luck
Old 04-03-2011, 12:20 AM
masterhacker1989
There was i thread i came across a few months ago where a guy did a trans mod where he doubled up on the gears for a BB engine, Ill see if I can find it
Old 04-03-2011, 06:00 AM
Mclovin350z
Eitherone of those with a foc should hold pretty good. With the picco 26 you may want a robinson first gearset.
