ZDZ with color
Old 03-11-2004, 08:49 PM
Forgues Research
My Feedback: (7)
Forgues Research's Avatar
Default ZDZ with color
Here is my ZDZ 210 with a bit of color.
Roger
ID:	110465   Click image for larger version
Old 03-11-2004, 08:57 PM
edgeman55
My Feedback: (25)
Default RE: ZDZ with color
Sweeet,I like the on board starter.Whats that beast going in?
Old 03-11-2004, 09:11 PM
Forgues Research
My Feedback: (7)
ORIGINAL: edgeman55-RCU
In a bigger beast, a 52% Edge by ACM
Roger
Old 03-12-2004, 09:27 AM
xp8103
xp8103's Avatar
Roger,
what starter are you using?
Old 03-12-2004, 10:19 AM
Forgues Research
My Feedback: (7)
ORIGINAL: xp8103
Roger,
Nik,
The starter is custom made by a company in Texas.. They make them for all kind of engines. You have to send them the engine and they make and custom fit the starter. Not Cheap though.
Roger
Old 03-12-2004, 11:03 AM
JohnVH
My Feedback: (38)
JohnVH's Avatar
mmmmm, get us some video of that big plane! I want one!
Good luck!
JV
Old 03-12-2004, 12:16 PM
Forgues Research
My Feedback: (7)
ORIGINAL: JohnVH
Good luck!
JV
John,
It won't be ready to fly until late summer, in the mean time, have a look at my 34% construction and go down the page, you can see a size comparison of the Big Edge with my daugther which is 5'6".
34% Edge
Roger
Old 03-12-2004, 12:22 PM
Hobbsy
Hobbsy's Avatar
Roger, that is one beautiful engine.
Old 03-12-2004, 01:26 PM
Forgues Research
My Feedback: (7)
ORIGINAL: hobbsy
Thank you. I'm considering doing my ZDZ 100NG in Green.
Roger
Old 03-12-2004, 01:50 PM
bdphil
My Feedback: (26)
bdphil's Avatar
Roger,
Nice jugs! What did you use for color? Paint, powdercoat? Also, I have a ZDZ80 that just about wears my arm out to start sometimes, can you tell me who did your starter and about what you have in it ($)?
Thanks!
Ben
Old 03-12-2004, 02:04 PM
CAPtain232
My Feedback: (40)
Roger,
How much weight did that starter add.... COMPLETE with battery and everything
Old 03-12-2004, 03:05 PM
Forgues Research
My Feedback: (7)
ORIGINAL: bdphil
Roger,
Thanks!
Ben
Hi Ben,
I use an anodizing paint good for 500 degrees that the hotrodders use under the hood of there cars. I also bake the paint.
As for the starter, Its from a company from Texas called Brookside Machines. They do all kind of starters for all kinds of engines. The down side, you have to send your engine in for fitting. This my second one, the other one is gone to a UAV company.
The price, well as they say if you must ask, you can't afford it , but I'll tell you anyway, this one because of the Astro Cobalt 40 motor used, cost $500.00 plus shipping. Not cheap.
As for your ZDZ 80, there is a better way to start it without flipping through the way you do.
Close choke, full throttle, and then instead of flipping through, just rock the prop from side to side just bumping the compression. You will hear the carb sound change when the fuel gets there. Then Throttle to idle, open choke, ignition on, and voila, 1 flip most of the time.
Roger
Old 03-12-2004, 06:33 PM
bdphil
My Feedback: (26)
bdphil's Avatar
Roger,
Thanks for the starting tip, I'll try that. Flipping it through would sometimes take 15 flips and sometimes 5, just depending on what mood it was in.
$500 isn't outrageous from the looks of the components in that electric start. It would be nice to flip a switch and go.
Thanks for the info!
Ben
Old 03-12-2004, 07:17 PM
Forgues Research
My Feedback: (7)
ORIGINAL: CAPtain232
Roger,
The starter itself is 28 oz. I haven't checked with the batteries yet, but it needs 1800ma at 24 volts, plus the ESV. Since the engine is quite lite for its size, I can use the weight in front on the EDge.
Roger
Old 03-12-2004, 07:18 PM
Forgues Research
My Feedback: (7)
ORIGINAL: bdphil
Roger,
Ben
$500.00 is quite expensive, but don't forget, every starter is different and is matched and tested at the factory.
Roger
Old 03-14-2004, 02:41 PM
flier
My Feedback: (7)
aerografixs
What is the brand name of the paint you used?
Where did you get the paint?
How much $ for the paint?
Can you tell I want some?
Thanks for your help,
Duane
Old 03-14-2004, 06:22 PM
Forgues Research
My Feedback: (7)
ORIGINAL: flier
aerografixs
Duane
Get in touch with me back channel
Roger [email protected]
Old 03-14-2004, 06:24 PM
Forgues Research
My Feedback: (7)
ORIGINAL: flier
aerografixs
Duane
Old 03-14-2004, 07:12 PM
Scott Claboe
My Feedback: (9)
Doesn't ZDZ now sell engines in a bunch of differnt colors.I heard it's a heat disapating paint to keep temp down in high torqe situations and overall temp down.
Old 03-15-2004, 09:07 PM
Shortman
My Feedback: (21)
Shortman's Avatar
Well I see it advertised now, but doesn't say if its for all motors or just the new big beast[8D].
Old 03-15-2004, 10:08 PM
Forgues Research
My Feedback: (7)
ORIGINAL: shortman
Hey guys, you want color, send me your engines.
Roger
Old 03-15-2004, 10:25 PM
rmh
rmh's Avatar
Some paints can insulate - some reflect and some are conductive .
I wish I knew what kind of numbers on changes from plain cast aluminum are really possible.
Anybody have any numbers
How is the test performed?
We all know that black cars get hotter in the sun-- but how is the paint making the aluminum give up heat more rapidly?
Or is it allowing the air to flow deeper into the fins?
I am a bit lost on this one.
Old 03-15-2004, 10:47 PM
flier
My Feedback: (7)
Hey Roger,
I picked up a can of the "Dupli-color Metalcast" (in blue) and painted the cyl.& prop washer of my ZDZ-40RV.
Then I wanted to bake it, like you did yours, so in to the over it went at 250 for 15 mins.
The results are very good.
Thanks for the help
Old 03-15-2004, 11:01 PM
Forgues Research
My Feedback: (7)
ORIGINAL: flier
Hey Roger,
Thanks for the help
How about a picture??
Roger
Old 03-16-2004, 07:03 AM
flier
My Feedback: (7)
Roger
I'll see what I can do to get a pic up.
ID:	111968   Click image for larger version
