Go Back  RCU Forums > RC Boats > Speed - Electric
My new props from ABC
Speed - Electric For all your electric boating needs.
Old 07-21-2022, 11:51 AM
Clugh
Banned
Default My new props from ABC
Just received...
2x 1818-10-50(2)
2x 1918-10-50(2)
1x 2018-10-50(3) L
1X 2018-10-50(3) R
1x 1924-23-38(2)
1x 1923-23-28(2)
1x 1524-23-38(2)
The saw props have AR of 2.3 and 2.4 they have a BAR of .38 and a 23 degree rake.
Spruce and glue is coming soon enuf!
Hubert
Justaddwata (07-22-2022)
Old 07-22-2022, 08:09 AM
Clugh
Banned
The 1818 is for Q S and T sport hydros in two lap or oval trim but Im at a Delima with these aspect ratios and the straight shaft angle in Finlay plans. Its 6 %. A 6 degree angle of attack on this prop only promotes more lift and drag. I have a long 1/8 wire drive but I dont know if id want to put a bend in it to set a strut AOA of zero degrees. I dont see the need to add lift to these props in AOA setup. I may switch to 1/4 inch flex but I really didn't want to do that. I guess id accept 3 degrees in a straight shaft setup. I really need articulated ball pin universals to take advantage or straight shafts but I think that's a stretch at 90000. For a 30000 rpm something can be built of the lathe.
Old 07-22-2022, 08:32 AM
Clugh
Banned
Here s some theory with the prop and my hand wound motor. Specifically wound in a Kv suitable for 10 s lipo in a boat.
Here is the Plot data based on the motors measured constants size type and weight:
33,940 rpm
153 amps
Pin 6.394 kilowatts
Pout 6.125 kilowatts
Run time 3.85 minutes
Est speed 90.12 mph or 145.03408 km/h
Eff. 95.80 %
Rm .oo5 Ohm
Kv 824
Io 3,27 Ampere @ 22,5 Volt einschließlich Radiallüfterlast.
Gewicht 448,8 Grammut
They are here also to put into you own calculators but here is the straight math on the motor for peak Eta....
Should be an excellent T or S sport hydro motor. It will power an 1/8th scale beautifully though not approved in a sanctioned 1/8th scale class. Its only 448 grams!
Regards,
Hubert
Old 08-17-2022, 05:52 AM
Clugh
Banned
Tell TSDAVIS he can come here if he wants to see the high current motor rewinds in the boats!
Thank you
Hubert
Old 08-17-2022, 05:59 AM
Clugh
Banned
90,000 RPM she has a stainless steel sleve
Hubert
Old 08-17-2022, 06:05 AM
Clugh
Banned
My other new toy
Hubert
Old 08-17-2022, 06:06 AM
Clugh
Banned
10 channels of Futaba. Ordered and on the way....
Old 08-17-2022, 06:17 AM
Clugh
Banned
MAMBA XLX 2 FEATURES:
Input Voltage Range 3S-8S LiPo (33.6v max)
Sensorless, SmartSense™ and Brushed Running Modes
Powerful Integrated 20A Peak Adjustable BEC (5.25V-8.0V)
CRYO-DRIVE™ Technology minimizes the amount of time the ESC’s electrical components spend generating heat, resulting in improved thermal performance during partial throttle operation where the majority of driving occurs
ESC is housed in a rugged CNC aluminum case and potted in waterproof epoxy to protect the electronics and promote efficient heat transfer
Premium forged heatsink with elliptical fins for superior air flow and increased heat dissipation
Oversized factory equipped thermally controlled 50MM cooling fan
Compatible with S.BUS2 Telemetry Link and Futaba T4PX, T7PX and T7PXR transmitters
Mounting holes located in bottom of aluminum case for affixing to your vehicle
Waterproof design for all weather conditions
Data logging capability to capture and record performance data from your vehicle
Auxiliary wire functionality for "on-the-fly" adjustments using your transmitter
Audible alerts for easy diagnosis of common issues such as motor-over-temperature and low-voltage cutoff
Convenient transmitter programming for six common adjustable settings including cutoff voltage and drag brake
Easily tune and update ESC with USB and Bluetooth™ programming options
Castle Link USB programming kit (coupon included with purchase)
Optional smartphone-based programming with the B-LINK™ Bluetooth Adapter (sold separately and Castle Link all available on Google Play or Apple App Store)
Proudly designed and manufactured in Olathe, KS USA and backed by Castle Creations' 1-year warranty
MAMBA XLX2 ESC COMES WITH:
Mamba XLX2 ESC
300mm Direct Connect Sensor Wire
Mamba Decals
Coupon for free Castle Link USB
Mamba XLX2 Quick Start Guide
Sensor port dust cover
USD $329.95 /EA
Old 08-17-2022, 06:23 AM
Clugh
Banned
And tell TS absolutely a castle controller can run a plettenburg tetras and that Spruce and glue will be continued right here right now.
Old 08-17-2022, 06:27 AM
Clugh
Banned
And this should make for a pretty good prop at 30,000 rpm
Old 08-18-2022, 05:46 PM
Clugh
Banned
I know you've all seen the marine vesrion. due in late this month! RIGHT???
AVAILABLE FOR PREORDER, ESTIMATED SHIP DATE: LATE AUGUST
Castle is excited to return to the boat market after a decade long hiatus. We are pleased to present the Hydra XLX2!
The Hydra XLX2 is based on our popular and powerful Mamba XLX2 ESC. We've removed the air cooled heatsink and added a watercooled heatsink. It is finished off with an aluminum top plate for a clean look. Attached to the top plate are two aluminum, water fittings for 1/8" tubing and uses standard 10-32 UNF threads; package includes optional .17" fittings.
CRYO-DRIVE™, Castle’s proprietary breakthrough technology integrates unique software and dedicated hardware to reduce heat and dramatically increase performance. Thousands of times per second, the XLX2 software minimizes the amount of time the electrical components spend generating heat. These software advancements work in parallel with an open housing design which enables increased directional airflow to cool critical components. With the combination of a new 50mm fan and forged elliptical fin heatsink, the XLX2 maximizes airflow throughout the system, taking thermal performance to a whole new level. The results are more power handling, cooler ESC temperatures and longer runtimes and for ultra-high performance.
NOTE: Due to the high power nature of the XLX2, you must use appropriately sized batteries and connectors. We recommend a minimum 150 amp connector for the Hydra XLX2; examples include Castle 6.5mm polarized, EC8 and QS8. DO NOT USE XT90, Traxxas, EC5/IC5 or any other connectors rated below 150 amps continuous.You can easily optimize the ESC for any running conditions. Create, save and download setup profiles through the Castle Link Programming Suite on your Windows™ PC, or wirelessly with the convenience of the new B-Link™ Bluetooth™ Adapter and Castle Link app for Android or iOS.
Additional tuning flexibility awaits you with on-the-fly adjustments from your transmitter via the Auxiliary wire. Simply connect the white signal wire to an open radio channel, and enable the feature in Castle Link by selecting what Auxiliary function you would like to use. Access programming parameters such as Torque Control, Max Brake or Max Throttle.
HYDRA XLX 2 FEATURES:
  • Input Voltage Range 3S-8S LiPo (33.6v max)
  • Sensorless, SmartSense™ and Brushed Running Modes
  • Powerful Integrated 20A Peak Adjustable BEC (5.25V-8.0V)
  • CRYO-DRIVE™ Technology minimizes the amount of time the ESC’s electrical components spend generating heat, resulting in improved thermal performance during partial throttle operation where the majority of driving occurs
  • ESC is housed in a rugged CNC aluminum case and potted in waterproof epoxy to protect the electronics and promote efficient heat transfer
  • Machined water-cooled heatsink with water fittings for 1/8" tubing.
  • Compatible with S.BUS2 Telemetry Link and Futaba T4PX, T7PX and T7PXR transmitters
  • Mounting holes located in bottom of aluminum case for affixing to your vehicle
  • Data logging capability to capture and record performance data from your vehicle
  • Auxiliary wire functionality for "on-the-fly" adjustments using your transmitter
  • Audible alerts for easy diagnosis of common issues such as motor-over-temperature and low-voltage cutoff
  • Convenient transmitter programming for six common adjustable settings including cutoff voltage and drag brake
  • Castle Link USB programming kit (coupon included with purchase)
  • Optional smartphone-based programming with the B-LINK™ Bluetooth Adapter (sold separately) and Castle Link all available on Google Play or Apple App Store)
  • Proudly designed and manufactured in Olathe, KS USA and backed by Castle Creations' 1-year warranty
Hydra XLX2 ESC COMES WITH:
  • Hydra XLX2 ESC
  • Castle Creations Decals
  • Coupon for free Castle Link USB
  • Hydra XLX2 Quick Start Guide
Old 08-23-2022, 04:23 AM
Clugh
Banned
The 10 channel Futaba was 811.00 to the door... One of the boats powered with the APD may end iup with a beta flight capable flight card for self leveling options and low pass filtering on a single layer motor for lower motor THD and noise.
The APD inverter is capable of 40 kW!! Its 20S lipo....
It cost me $1200.00
Regards
Hubert
U can never have enuf options.....
Old 08-23-2022, 03:54 PM
Clugh
Banned
I have to have this. I guess it will have to be scratchbuilt from Newton plans. Maybe I should build a plug for a mold so this will never have to be done again. I contacted James Lusczc (ML Boatworks)he's never rendered the kit from Rogers plans. Ive ordered the plans so I guess I build it from balsa then laminate it with cf if I don't decide on it being a plug. I assuming no one in either American sanctioned body owns one?
U-31 Circus Circus 1990
159-A
Master Hull Roster#
9031
Regards,
Hubert
Old 08-24-2022, 02:02 PM
Clugh
Banned
Old 08-24-2022, 02:04 PM
Clugh
Banned
Old 08-24-2022, 02:38 PM
Clugh
Banned
Tell TS Davis and all the advanced boaters that actually know something about mathematics physics and electronics from IMPBA and NAMBA interested I'm here with my high pitched propellors, high current motors, and inverters for the electric boats. Here we will put theory to test.
Talk is cheap....and a castle inverter will run a Plettenburg tetras with no issue!
Regards
Hubert
Old 08-25-2022, 06:45 AM
Clugh
Banned
159-A
Master Hull Roster#
9031
Old 08-25-2022, 07:40 AM
Clugh
Banned
You all probably know about this but here is the theory behind such an unlimited for those they may not know.. I think it still applies and would like to expand upon it by making the surfaces truly active .
– Integrated rate gyro, compact size, and light weight
– 3-Axis Gyro plus 3-Axis Accelerometer
– Auto recovery
– Four flight modes: (Auto recovery/Normal/AVCS/Gyro OFF)
Supports 2 ailerons, 2 elevators and 2 rudders types
Old 08-25-2022, 07:53 AM
Clugh
Banned
Old 08-25-2022, 07:56 AM
Clugh
Banned
If you got 35 minutes enjoy the history and the history of the blowover!
Old 08-25-2022, 11:08 PM
Clugh
Banned
Running a 180 MHz 32-Bit processor these will deliver maximum smoothness, unmatched linearity, with ultra-fast throttle response for unsurpassed flight control. With peak power ratings up to 30kWs, these ESCs will have no trouble powering your craft.
The APD developed (proprietary) firmware ensures unmatched low-throttle and starting characteristics. Ultra-smooth starting and ramp-up characteristics ensure your drive-train is safe. Features include PWM-frequency dithering to avoid PWM-commutation synchronisation, adaptive motor timing advance and proprietary developed Active Phase-Current De-magnetisation (APCD). APCD along with Synchronous rectification ensure maximum ESC efficiency is achieved.
Designed and manufactured in Australia using only the highest quality components, ensuring no sacrifice in reliability.
Aerospace grade ceramic capacitor bank for lowest possible ESR and maximum reliability, no more dried up electrolytic failures!
Multiple operation modes:
Normal:
Normally used for watercraft and aircraft not requiring reverse.
Incremental + Linear power ramp control.
Multirotor:
Instantaneous input = Output Step Response.
Heli:
Soft-start for drivetrain protection.
Traction:
Same as normal except for active torque control, which applies a motor phase current limit that ramps proportionally with higher motor duty-cycles.
Plug and play firmware
True 12bit throttle resolution
Feed-Forward compensator
Up to 480Hz input update rate (Standard PWM)
Runs Oneshot125, Mutishot and Proshot Up to 32Khz
Over 1,000,000 eRPM
Auto PWM-freq
Auto Timing Advance
Onboard 16Mbit Flash memory – Data-logging
Firmware updatable through micro-USB port
Isolated Input and output (Can be configured for RPM)
Fully configurable through the APD ESC Config Tool (micro-USB Connection)
Optional external capacitor board for >1m input lead lengths: Cap Board
* Continuous current ratings are at a 100% throttle duty cycle. Continuous rating is defined as max sustained current at 100% throttle for 180 seconds with 10 m/s airflow.
Weight 220 grams
Size: HV Pro 77x52x27mm, HV14 96x52x22mm
Optical isolation
HV 14S(60 volts) 240 amps constant, 360 amps surge
HV Pro 16S( 70 volts) 400 amps constant, 600 amps surge
HV Pro 20S(85 volts) 300 amps constant, 450 amps surge
HV Pro 24S(100 volts) 200 amps constant, 450 amps surge
COST $1,125 .00 usd
I BETA TESTED THE PROTOTYPE WHILE WORKING AT DAIMLER AND TOLD STEVE THIS WAS A SURE BET
SO HE BIT
GERBEN VAN BURKUM HAS ALREADY WON WORLDS WITH THE F3 200
APD BRUSHLESS MOTOR SPEED CONTROLS US STOCK (neumotors.com)
This is not a sea king 180 it is the lightest most power dense and advanced hobby inverter in the world.
Old 08-25-2022, 11:31 PM
Clugh
Banned
This is the real deal!
Old 08-25-2022, 11:47 PM
Clugh
Banned
Anyway the laser kit for a U-31 Circus Circus 1990 159-A Master Hull Roster #9031 will be cut so i can start gathering running hardware for the boat.. The cooler the electronics the more delivery you will get. So dual water pickups is a start.. I usually go with virginia craftsmen fin but I think ill try RRC this time. I like the finish quite a bit.
Old 08-26-2022, 12:22 AM
Clugh
Banned
Im starting out with a 1/8 in wire drive setup but I have the plans and procedure from Jimmy for the ball pin universal cutting tool that can withstand the torque. These can be turned, with this tool. in O-1 tool steel.
Old 08-26-2022, 12:52 AM
Clugh
Banned
The wire is a very nice manufactured piece setup for a 1/4 inch strut with a stepped down to .187 for the prop bores I'm running. I also keep an assortment of K&S scratchbuilt 1/8th inch wire drive stock on hand. Now that i have the lathe turning the ferrules is no issue.
Contact Us - Manage Preferences - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service -
