Functional antenna
My Feedback: (61)
Functional antenna
I just finished a Global P47 ARF and I added a functional antenna mast by using some left over gutter material from a doll house kit (U channel) and capped it off with a strip of balsa to make the raw stock square with a square hole,than shaped it to the proper shape,glued it to the fuse in the stock location and routed my antenna through it.
