Which one?
Old 07-26-2008, 03:29 PM
madman75
madman75's Avatar
Default Which one?
I was having a discussion with a flying buddy about oils. I said I used Pennzoil 2-cycle air-cooled oil and he said that I should use Pennzoil outdoor 2-cycle air-cooled oil. The one I use is in the 3.2 oz. bottle and the other is in the 8 oz. bottle. He says the one I use will destroy my engines. Mine are still in the break-in period at 32:1. Which is the proper oil to use? I need to get some more oil as I just mixed 1.5 gal. more. If I'm using the wrong stuff, I'll use it my weed eater. I have already run 1.5 gal. between my 2 50cc engines.
Old 07-26-2008, 03:39 PM
Hughes500E
Hughes500E's Avatar
Default RE: Which one?
I'd hate to be in the building where they are running the 2cycle air cooled
Amsoil for me!
Old 07-26-2008, 05:32 PM
pe reivers
This horse has just been beaten to death here.
http://www.rcuniverse.com/forum/fb.asp?m=7772694
Old 07-26-2008, 07:42 PM
madman75
madman75's Avatar
I read the whole thing, I was a little confused. Are the two oils the same? Is it just that the 8 oz. bottle has the updated label as compared to the 3.2 oz. bottle or are they different. I went to Pennzoil's web site and still didn't find a definite answer.
Old 07-26-2008, 08:29 PM
dbcaster
You should use the Pennzoil aircooled, not the outdoor.
Old 07-26-2008, 08:34 PM
dbcaster
Also, I really doubt either one if mixed properly would destroy your engine. I would ask your flying buddy where he got the idea that either of the Pennzoil products would destroy any two stroke engine.
Old 07-26-2008, 08:40 PM
AirWizard
AirWizard's Avatar
I have used the aircooled for years with no problems.
Old 07-26-2008, 10:02 PM
BTerry
My Feedback: (8)
Air-cooled = air-cooled. The bottles have different labels, that is all. The other formula is "multi-purpose" and is not for air-cooled engines. If the label says air-cooled you are good to go. The newer bottles say "Outdoor" on them, and it is a marketing thing. The basic oil is the same as it used to be when they used the plain yellow bottle.
Old 07-26-2008, 10:52 PM
dbcaster
Yeah I just checked my bottle and it says Outdoor aircooled with blue labeling. From what I have read this is the one to use. The other is the multi-purpose and has brown labeling.
Old 07-26-2008, 11:30 PM
madman75
madman75's Avatar
Thanks all. I'm glad they are the same. I can the bigger bottle for 50 cents more.
Old 07-27-2008, 07:51 AM
Jezmo
Jezmo's Avatar
Yes, it is the one labeled "Multi-Purpose" that is different. Both share the Outdoor label now but the labels are different colors as mentioned above and the Blue Label "Aircooled" is the one you want.
Old 07-27-2008, 09:01 AM
pilot727
I have a DA-50 and broke mine in on stihl oil, i put five gallons or about, then i went to Klotzs at 17 dollars a quart it has to be good and i also use chevron gas with tecron in it and the engine runs so much cleaner
