Help needed with ZDZ 80 super
Hi there,
I have a new ZDZ 80 super engine and having some problem to hook up linkages to carb and choke. The hardware which came with this engine has two metal half arms with ball links. I will appreciate if you some one can explain me an easy way/method to attach these arms or other linkages to the carb and choke. Picture will be a great help too, thanks.
Jamal
Jamal
My Feedback: (17)
QC, CANADA
RE: Help needed with ZDZ 80 super
Check this thread post no-496 here
I have used the RCS linkage with good success, and they now have a newer version that ships...
you do grind the peened head off the shaft and slide this into position and secure with a set screw. Adjustable around the shaft makes it nice to place the ball where it's most advantageous.
http://www.rcuniverse.com/forum/m_33...20/key_/tm.htm
