Drawing or plans for Tank
I have been kicking around an idea about building a scale tank somewhere between 1/4 or 1/5 size for my grand son. I have at my disposal an electric powered wheel chair that will operate either both motors together to go forward or let one slip and the other pull to turn push will operate in reverse with same contorls The chair will handle about 350lb peron so aft wood from and track a 10 year old should not weigh enough to stall it out. So Im looking for side views,, friont views, top down views and rear view' so i might have a chande at building somethingNot truw detail but close enough
RE: Drawing or plans for Tank
Most people will buy afv books by George Bradford with drawings/plans and then get them enlarged at a print shop. He has a a lot of different books available. Here is a very good site, mostly 1/6 size but it does have other links to sites with supplies and such http://www.rctankcombat.com/ http://www.rctankcombat.com/tanks/ Also here is a decent site http://www.onwar.com/tanks/ I hope this helps.
Cheers,
Wade
Cheers,
Wade
This is something that has come up before on this site.
Have no knowledge beyond what you see on the webpage.
http://www.gizmology.net/tanks.htm
EDIT -
I guess one was not enough...
http://www.gizmology.net/tankshowroom.htm
EDIT -
