Big block t maxx Help PLEASE!!!!
Old 01-12-2009, 08:30 PM
laganm21
Default Big block t maxx Help PLEASE!!!!
I have a big block tmaxx that I just bought with no motor so i got a Axial .28 the problem is that i have a 72tooth metal spur gear so i have to buy a harden steel bell gear but the gear that robision racing makes the bell is self is smaller than the stock t maxx bell so the cluch just burns up because the cluch its self has no room to expand in the robison racing harden steel bell gear dose any body know of another Company that make a harden steel bell gear to run with a metal spur THANKS
Old 01-12-2009, 08:42 PM
fabrimacator21
Default RE: Big block t maxx Help PLEASE!!!!
How are you running a clutbell thats smaller then the stock tmaxx bell on a bb motor?
What pitch is the steel spur? Smallblock motors run a 8.0 pitch on the spur and clutchbell and big blocks run a 1.0 pitch which means you will need a 1.0 pitch spur gear to fit a 1/8th scale clutchbell. I'm running the mgt spur (1.0 pitch) with a savage clutchbell.
Here is a link to the plastic spur: http://www.hobbypeople.net/gallery/372138.asp
Old 01-12-2009, 08:46 PM
laganm21
i cant run the stock tmaxx bell gear because i have a steel spur gear so the stock one wil strip out because the metal is too week so i have to buy the robision racing harden steel bell gear for the tmaxx but the bell is i little bit smaller than stock
Old 01-12-2009, 08:52 PM
fabrimacator21
Is the clutchbell for 1/8th scale big blocks?
If it is it won't work with the spur you have. The teeth are different pitches which means they won't mesh properly and will strip no matter how hard the steel is.
Old 01-12-2009, 09:03 PM
laganm21
ok let me clear this up the truck was a t maxx 2.5 ok i got the big block kit for it the trans is the stock 2.5 and it had the robision racing metal spur gear 72 tooth and the cluch bell 20 tooth harden steel the bell that robision racing make is a little smaller than the STOCK tmaxx chuch bell every thing works fine with the big block and the gears meshing with the stock flywheel and cluch but just the bell gear they make the gear is FINE is just the bell its self is a little to small and the cluch can not expand if u bough tthe 3.3 herden steel gear would that have a bigger bell OR what outher metal gears can i run on the stock 2.5 trans will the savage 2.5 spur work on the trans
Old 01-12-2009, 10:31 PM
fullyford
fullyford's Avatar
i have steel spur gear on my tmaxx with a picco .21, stripped one clutch but that was my own fault. i just use stock tmaxx clutch bells, nothing special
Old 01-21-2010, 01:50 AM
victrolla
I can tell you that the fix for this if it's a T-maxx big block conversion that started out as a T-maxx 2.5. I used to change my clutch shoes every 3 tanks on my T-maxx big block conversion until I figured out that you can get a complete 1/8 clutch assembly (which is Mod 1) and the Robinson racing products spur and slipper for the Monster GT (which is also Mod 1) to replace the 1/10 scale clutch (which is Mod 0.8). The 1/8 scale clutch is the only way to handle real power and the RRP slipper and spur for the Monster GT fits the T-maxx 2.5 input shaft exactly . The diameter of the RRP spur for the Monster GT is between the two RRP T-maxx sizes so it happens to end up with an ideal final gear ratio, it has great low end power and top speed. For my conversion I had to use used the largest clutch bell and elongate the slots in the chassis with a rat-tail file so that the motor would slide over a little closer to spur for perfect gear mesh. It sounds more complicated than it is because it's harder to write an explanation than it is to speak it. The clutch assembly I used was by Ofna but I think 1/8 is all the same standard size except for Losi which has a different reach. I'm on my 3rd set of aluminum transmission gears and the clutch hasn't slipped at all.
So largest number tooth Ofna or equivalent 1/8 scale clutch assembly, RRP slipper and spur for the Monster GT and some light filing.
Old 01-21-2010, 10:29 PM
nitro stan
put a plastic spur on it. that steel spur is gonna cost you a lot of tranny parts. you can also get a torque control slipper upgrade kit for that transmission. thats what i did to mine and it holds up great
kit
http://www3.towerhobbies.com/cgi-bin...?&I=LXSGN1&P=7
im running a TTR.28 in mine, same as the .28 in the AE monster GT 4.60
Old 01-29-2010, 03:00 AM
fabrimacator21
ORIGINAL: laganm21
I run a stock savage clutch bell on my picco but I run a plastic spur....... Get yourself a 1/8th hardened clutchbell and run MGT spur gears to match the 1/8 gear pitch. I run Mgt plastic spurs on my .28 picco (big block pitch) and have NEVER stripped one due to power.
