Gas-oil mixture
Gas-oil mixture
Hey guys,
I know, this is an old question, but I can't find the table for mixing gas and oil for all the commonly used mixing proportions. Perhaps somebody remembers where to find them. I certainly appreciate it if you could repost it.
My Feedback: (34)
VA
RE: Gas-oil mixture
1 gallon = 128 ounces
32:1 = 128/32 = 4 ounces/gallon
50:1 = 128/50 = 2.56 ounces/gallon
75:1 = 128/75 = 1.71 ounces/gallon
100:1 = 128/100 = 1.28 ounces/gallon
My Feedback: (40)
IN
RE: Gas-oil mixture
One of the best things you can buy for running your gas engine is the handy dandy mixing cup from most motorcycle shops. I forget what it is actually called, but it has markings on it for all sorts of ratios. Basically you dump oil in it until you read the appropriate ratio under the correct gallon column. Then dump the oil in your gas can and gently shake. No guessing or calculating at all.
