OS 160 FX Pressure Tap
Hi Everybody,
The tank in my model in far from the firewall and, frequently, my OS 160 FX stop (naturally, during inverted flights ...).
I would like to install a Cline regulator.
Where to buy it ?
I have seen it's necessery to have a Pressure tap on the crankcase to use this device.
Is it necessary to modify the engine to install this crankcase Pressure tap ? How to proceed ?
Where to buy it ?
RE: OS 160 FX Pressure Tap
Here's your pressure fitting.
Replaces the top left back plate retainer bolt.
http://www2.towerhobbies.com/cgi-bin...?&I=LXWY11&P=Z
Cline regulator
http://www.billsroom.com/pcfs/
Iron Bay Regulator
http://www.ironbaymodelcompany.com/W...or%20Main.html
The 160FX will do pretty good with a Perry pump instead of a Cline.
http://www.perrypumps.com/prod02.htm
Enjoy,
Jim
Cline regulator
Iron Bay Regulator
Enjoy,
Jim
Thanks W8ye for your help,
For which device have you a preference between Cline Regulator, Iron Bay Regulator and Perry Pump ?
Thierry
Thierry
That's OK !
I will order and I will install the Pressure Tap and a Regulator.
I hope I will have no more flame out from my OS 160.
Thanks !
Thierry
Thanks !
Thierry
