Wren 44 ECU
Wren 44 ECU
Anyone have, or know where I can get, a pre-2010 ECU for my gas start Wren 44? I figured someone may have had their engine converted to kero start which would require the early ECU to be replaced with the newer one. This is the one I have...…and need a replacement.
Rich
Rich
Hi Rich
have you tried contacting Wren to see if they might have the older ECU as they take the older ones in when they do an upgrade , at least thatt way you know you are getting a working one ?
Thanks for the suggestion, Stegl. Tried exactly that and the folks at wrenpowersystems.com were extremely helpful. Bought a replacement early ECU and we're back up and running. Thanks again!
Rich
Rich
bearing change by previous owner . Had a little issue with the pump as it had sat for several years but fixed that on my own. Runs flawlessly
with propane start . Just had to replace one glow plug ( regular rc type... cheap as heck) so far .
Either that is one of the first ones ever made or it almost appears to have been rewrapped with heat shrink...... ?
You might try looking at putting in a wanted add in RCgroups to see if you can find one. Supposedly they have a new buyer
in the wings to keep things going. The Wren 44 TP I have has the older ECU and when I need service ; subject to them reopening;
one of the first things I will do is upgrade to the new Xicoy V10 ECU as those should be available for a long time to go as the older ESC's will gradually dry up.
http://www.turbinesolutions.co.uk/
these they guys ; apparently they are doing Wren repairs.
Thanks steal. Actually, a lot of the early version Wren 44 Manual Start engines had this style of Fadec. Just have a look at the first few images here: LINK
Anyway, i think I may have figured out my problem. Fingers crossed!
You may find that contacting Turbine Solutions will solve your problems - Fadec V-10 ECU . Jet Central Sales and Service, Fuel Tubing, Pneumatic Fittings, RC Jets - Turbine Solutions
modtron
Oxford UK
modtron
Oxford UK
Wren service by Turbine Solutions
I have just received my Wren 44 TP back from Turbine Solutions in England and am more than happy with the major service I needed.
Highly recommended.
Highly recommended.
