Cupid
Cupid
Anyone having trouble with the new Cupid's ?
Charged batery run it up to check trim and flybar control link broke in half didnt even get it off the ground ?????
ive owned and flown a feda dragonfly , it was fine out of the box , the cupid hmmm
RE: Cupid
Hi
One thing I need to add on Cupid. I heard and saw what it appeared to have brash ball in the swash plate already. Some say it is compatible to Dragonfly. Damn.. I should have bought it on the day it arrive in Singapore. Heard that the swash plate are sold out in Singapore.
Super-Hornet
Super-Hornet
RE: Cupid
The set screw that holds the flybar must have been tightened too much. Accidents happen, unfortunately. Luckily it's not an expensive part to replace.
RE: Cupid
repaired and been through about 6 packs now and it seems to be ok , dunno what happend , could have been worse i guess , one thing sucks on the cupid is that battery pack holder , hard landings the pack slips out have to change that to somthing else, the dragon fly has way better pack holder ,
BC, CANADA
RE: Cupid
I've been flying mine since Christmas. Very stable and lots of power. I've had problems with the rotation assembly holder constantly snapping where the blades attach. Anyone know of a stronger upgrade part for this?
RE: Cupid
How do you repair, with the crappy instructions included?
It took me several hours to figure out how to get everything
put togather. Repairing it will be next to impossible.
BC, CANADA
RE: Cupid
Mine came fully assembled and ready to fly. I've had no problems repairing so far. I've broken a few main rotor blades and several rotation assembly holders and that's it. I use the Hummingbird Main blades, they seem to work better than the stock cupid blades.
RE: Cupid
I got a cupid EM-1001 and the tail motor has screwed up. does any body have suggestions. the motor doesn't have the wires connected to it and when i connest them the motor still doesn't work the rest of the heli works.
RE: Cupid
Hi heli
I can safely say that all micro heli has its tail motor with wire soldered. What is actually the problem u encounter on your BTT Cupid. Give us more detail so we can help.
Super-Hornet
Super-Hornet
RE: Cupid
the tail motor has burned up or something and the spare motor i couldn't hook up but i still think the black piece with the capicator on the stock motor fell off. the black piece on both of the motors is messed up. new tail motors are 16.00. I got the heli for christmas from my mom and dad and the price tag said 299.99. i m only 12 yrs old
RE: Cupid
also my batterys won't fully charge again. i used both of them maybe 5 times each and now when i try to charge them (to test tail motor still testing) it doesn't fully charge. i wear them down all the way and then charge them again.
RE: Cupid
Hi heli
If you capacitor fell off and if your tail motor still in working condition, you still can fly because the capacitor is only use for Electromagnetic Noise Reduction and also to reduce the spark in the brush contact point (In side the motor). Without the capacitor, your motor will dies off faster.
I assume u got the correct spare part for your tail motor right? So all u need is to remove the 2 screws and then replace the damage motor with the new one. Tighten it back. Oh... I believe your spare motor do come with gear attached right? U need that gear.
U need to desoldered the wire off and soldered back the wire to the new motor. Plz tell me u have soldering iron or u know someone who has it and know how to do it.
Super-Hornet
Super-Hornet
RE: Cupid
Mine came fully assambled from the box.
I've had mine for only two days, the first day was fun, on the second day my wife asked for a try, what a mistake, she throddled up and the heli came around towards her and she ran. It crashed into the concrete steps and broke the main rotor holder, where can I get parts?
Kim
Kim
BC, CANADA
RE: Cupid
I get my parts at Great Hobbies:
http://www.greathobbies.com/frame_index.html
You might want to buy a few of the Cupid Rotation Holder Assembies as I broke quite a few. I've also replaced motors once and main rotor blades several times.
Jim
Prince George B.C.
Jim
Prince George B.C.
RE: Cupid
Buy the dcm-166 motor for replacement of tail motor. It's only $0.75 each plus another $0.10 for a 0.1 uF capacitor. Save your stock tail pinion for the dcm-166 motor. dcm-166 motor has the same performance as the stock tail motor of jabo2 and can't tell the difference.
Super-Hornet,
CAn you post a photo of your helicopter? Where do you fly your helicopter? in the Yishan area?
Super-Hornet,
