Faster Truck
Old 08-01-2004, 09:35 PM
mt_100
Default Faster Truck
I am looking to get my current truck to go faster, or a new one that will really fly. Because I already fly RC planes I have all chargers and batteries lying around so I have an electric car as well.
My first option would be to modify my Duratrax Evader ST which is completely stock at the time. I happened on a better ESC that will handle down to a 13 turn motor and thought about picking up a 15 turn to get some good speed out of it. With this option I would suffer lower run times as I run in grass a lot and it does bog sometimes. I am also not sure if I need to change the stock gearing but I was considering getting a smaller pinion to help improve run a bit and 3000 mah cells to replace my current 1500 mah cells.
My second option is an HPI RS4 MT which is still electric but four wheel drive, which I think may get me more speed in grass but cost a lot more than modifying my current truck.
So what do all you experts recommend. Mind you this is for complete crazy jumping and bashing and I want to stay on the cheap to keep the cost down and the wife happy.
Thanks!
Old 08-01-2004, 10:29 PM
HPIDUDE
Default RE: Faster Truck
put a faster motor in the evader
Old 08-01-2004, 10:47 PM
Ahab
Ahab's Avatar
bang for buck the hotter motor seems like the way to go, if you get the HPI you can always swap the electronics onto it.....
Old 08-05-2004, 01:40 PM
shredder111
Get deans they add to performance.
Shredder111[>:]
Old 08-05-2004, 03:41 PM
evaderguy89
evaderguy89's Avatar
i just got a futaba s3003 servo in my evader. it turns to the right fine but it only turns to the left half way. can anyone help me out?
Old 08-05-2004, 04:49 PM
Losidude_2
Losidude_2's Avatar
ORIGINAL: evaderguy89
I have one too but mine works fine, did you put it in straight and proper, did you check your steering trim.
Old 08-05-2004, 05:20 PM
mt_100
Yeah, I have Deans already, knew about them from my planes.
Putting a 15 turn with an 17 tooth pinion in the evader, should help a lot.
Old 08-07-2004, 01:52 PM
mt_100
This is odd.
Put a Venom 15 turn motor in it and replaced the stock 20 tooth pinion with a 16 tooth. Now the speed is about the same, and the run time is down. Batteries are very hot after a run too.
Maybe I should go to a 23 turn motor and a larger pinion?
Any Ideas?
