DA50R
My Feedback: (26)
NC
DA50R
How do you hook up the ignition?
Use the supplied connector on battery pack and plug into ignition module?
Plug small wire from module and wire from pickup into jr charge switch?
Is this right? Thanks.
My Feedback: (10)
PA
RE: DA50R
small wires from module go to one side of you switch. The other side of your swith goes to the battery.
the larger wire from the module (in the red tube) conect to the wire from the pick up on the engine.
RE: DA50R
Unless I am reading you wrong, NO... the pickup wire
connects directly to the ignition module. Matching JR
connectors. Both wires have a red tubing over them.
The opposite wire from the Ignition module connects
to your battery source. NiCad or NiMh battery with
your switch in-beteen. Lithium battery goes battery to
switch to regulator to Ignition module.
Gerald
My Feedback: (26)
NC
RE: DA50R
Thanks guys.I had one of these engines a while back and I bought one to go on a Wild Hare Edge and I forgot how to wire it up,manual is not very clear on this.
Thanks again,Neal.
Thanks again,Neal.
