Power Switch hunt
NC,
Power Switch hunt
Hey Guys,
couple of weeks ago I found a switch for your jets that I would like to start using on my larger gas planes. I don't recall the name or manufacturer. I do remember that the switch has no moving parts. To turn off the switch, you have to insert a metal pin that has a small banner attached that says something like !QUOT!Danger Remove Before Flight!QUOT!. Could someone post a link or pm me with the address.
Scott
Scott
My Feedback: (24)
RE: Power Switch hunt
Scott,
If your using a regulator in addition to the switch, you could use the Duralite failsafe switch..... If the switch or wiring between the switch and regulator were to fail regulator stays in the on state until you unplug it from the battery.
