first flight
first flight
ok i have been in to building ff and r/c gliners for a few years and now i have got some airplanes that my dad built but never flew. he had a gillows mustang with a tee dee .051 and a ring master jr. with no engine. well i built the stunt chimp with the tee dee and i was courious if there is any advice for my first flight. what gas do use for the .051.
RE: first flight
DARKFLY,
The TD should run good with 15%-25% nitro and 20% lube, mostly castor.
If I remember correctly, the Stunt Chimp is a bit small for that engine. Assuming this is correct, I would use a minimum of 35' lines with 42' (.008 or .012 steel wire) probably a better choice.
Have you run engines before?
Good luck with your Stunt Chimp.
George
George
