TH .46 carburetor replacement
MI
While trying to tighten the carburetor on my TH .46 engine, I have broken the fuel nipple off inside the carb body. (my bad)
Since youl cannot get replacement parts for TH engines now does anyone know of a replacement carb that I could use and get back running?...all the posts I have read suggest the carb is not that great to begin with (had probs keeping tight and spotty midrange) so any ideas?
Engine is less than a year old and only bench run so would hate to moth-ball it..thanks.
RE: TH .46 carburetor replacement
I'm not sure that I could do it, but, if the carb body is not broken it should be possible to remove the broken nipple and install a new one.
edited to add:
If you do have to replace, Perry carburetors are available http://www.perrypumps.com/prod01.htm
You'll need to measure the tower carb and choose the closest match.
edited to add:
My Feedback: (15)
While at the field a month or so ago, a fellow flyer and I were combatting and got together and in the ensuing dirtnap, his carb nipple broke off clean with the carb. I was able to take a small servo screw and insert it in the hole of the nipple to get it to turn and I got it out. I replaced the broken nipple with a fuel nipple from a magnum engine. I think the part ( new nipple) was not over $2.00.
It might work for your engine?
John
John
MI
Thanks for the tip!....took a jeweler's screwdriver and got the nipple out....then swapped with the muffler nipple and put it on the carb....will plug muffler like you suggest until I can replace...thanks again.
