Fail Safe
Fail Safe
First of all, how does a fail safe know if you have lost radio signal, when it is put in between the throttle servo?
Also, I think that I am going to get the Ofna micro fail safe, is it the best one?
RE: Fail Safe
My brother and I use the Venom temp/failsafe/overheat failsafe is the better one, you get three different features from just one device. This Venom temp/failsafe/overheat failsafe will not work with Spektrum radio systems. If you just what/need a failsafe, then Venom or the Ofna are both great! You can find them on e-Bay easily.
RE: Fail Safe
ORIGINAL: dannyn
The reason failsafes dont work on spektrum 2.4 radio's, is that the RX has a built in failsafe, so that when the RX stops reciving a signal from the TX, it keep sending signals to the servo, setting it at whatever position you set when you bound your radio...
RE: Fail Safe
ORIGINAL: dannyn
SO is the Ofna the best one?
MA
RE: Fail Safe
I like the Dynamite failsafe and it's worked flawlessly just as my OFNA failsafe has. The reason I like the Dynamite is that it's case is transparent and I can see it's two color status LEDs through my Aftershock's transparent radio box. I also have four PCM receivers that incorporate a failsafe, I never run without a failsafe after making a stupid and catastrophic mistake. My radio's battery alarm was beeping and the car went into failsafe mode. Like an idiot I disabled the radio's battery failsafe to drive a little more, sure enough about two minutes later the car ( an OFNA Pirate M1) flew by me at wide open throttle and hit a curb and then a building. Needless to say it was destroyed, but on the bright side I had a parts car. I've never run without a failsafe whether it be a throttle return spring or a solid state failsafe since.
RE: Fail Safe
venom is the way to go it has a overheat fail safe also that you can set to what ever temp you want for 30 bucks you can save your motor ,my slipper nut got loose today and i got upto 290 max with my venom temp if i had a temp failsafe it would have cut off my moitor is fine but i could have blown it if i went any farther .
RE: Fail Safe
ORIGINAL: dkastil
RE: Fail Safe
I just have the temp after my almost oveheat today i orderd a temp fail safe off ebay 33 bucks is not much to save your motor i run large fields and if i did not have my venom that showed the min and max run temps I would never know i hit 290 because when i checked the cars temp it was never over 230 but when i clicked the min max button i was shocked ! I will never run without one agan
RE: Fail Safe
ORIGINAL: dkastil
