Do you put grease in the revo 3.3 tranny?
Old 05-04-2009, 08:31 AM
Novarider
Default Do you put grease in the revo 3.3 tranny?
I'm about to install a center diff in my revo 3.3 5308 and was just curious if I need to put grease in the tranny. If so what's a good kind can I just use diff grease I can pick up at a local auto parts store or is there special rc grease.
Old 05-04-2009, 10:34 AM
ridikt
Default RE: Do you put grease in the revo 3.3 tranny?
ive never run the center diff, but im pretty sure you dont put any grease in the transmission case itself. i think you just run your oil in the diff.
Old 05-04-2009, 11:21 AM
keithinspace
I don't think they suggest any type of oil or grease in the transmission.
I never feel comfortable with that, so I always put a few squirts of White Lithium Grease from a spray can before I seal the transmission up.
I would absolutely, positively not put a heavy "bearing grease" or other type of differential fluit in the transmission. That will only resist the normal motion inside the transmission...a bad thing.
Just a few dabs of oil on the gears or a very light application of a very light Lithium type grease is all I would do, if anything at all.
Old 05-04-2009, 01:21 PM
Novarider
ok thanks guys
Old 05-04-2009, 02:31 PM
madmaxx1
madmaxx1's Avatar
ORIGINAL: keithinspace
lubrication become's an issue when using metal gear's, it is not necessary to lube the stock plastic gear's but IF you decide to do so use what keith suggested [8D]
