traxxas
traxxas
howdy have a question i just installed the cvd kit in my nitro sport and since i have been having a problem. when i drive my truck the wheel nut tightens up on the drivers side of the truck to the point that the wheel will not spin.. if i would replace the brass type spacers in the axle carrier with bearings would that fix the problem?. thanks
traxxas
if you have bearings instead of bushings in your wheels, you give it something to tighten onto that still spins freely. the bushings are a solid pice of metal so when you tighten it, it will slow/stop the wheel.
with bearings there are moving parts to it. so the nut hits the center part of the bearing and clamps down while the outer part of the bearing(which is in contact with the rim) is allowed to spin as fast as the wheel will go.
1 Post
traxxas
If the wheel nut is tightening on the driveshaft, your rim is slipping on the driveshaft. Make sure the axle has shims between the rear hub carrier and the axle pin (if it isn't, the rim can skip over the pin and cause the problem you describe).
