futaba 9 cap
My Feedback: (51)
futaba 9 cap
I have a futaba 9cap that as soon as I turn it on it goes to "warning" mode and "idol down" like I have a switch for high rates or mixing on.
I have had this TX for 3 yrs and it has only done this when I left or bumped a switch on.
I have tried cycling the power switch, removing the Battery from Tx, holding down buttons as I turn on and off both and nothing seems to clear this. Anyone seen this before?
Thx
Marty
Thx
Marty
RE: futaba 9 cap
The 9Cap has several mixes that give warnings on power up.
It seems you have enabled both directions of a switch with a mix that gives a warning on powerup.
There is a way to bypass this but I don't remember what it is.
RE: futaba 9 cap
a good starting point would be to go to throttle cut in the menu and see what switch is assigned to the throttle cut then make sure one way you throw the switch is on the other way is off or inh
