Gluing Gas Tank on Savage
Anyone have experience gluing (glueing?) up a crack or 2 on their plastic nitro tanks? I have 1 small hairline crack (on a flat section) on mine and am curious what might work the best.
I was leaning towards using some epoxy meant for plastic, embed some fiberglass cloth in it and use some wax paper to spread it out. Prep would be to sand and clean with acetone.
To answer those that are wondering,,, yes I'm too cheap to buy one [:-]
AB, CANADA
RE: Gluing Gas Tank on Savage
Clean it really well, then just go down to your local automotive store and find an epoxy that is gasoline / alcohol resistant. yes I know that the fuel is actually nitro methane with oil, but any hydrocarbon resistant epoxy will do. There are tons to chose from, but the most important thing is to get the tank clean around the crack.
Another alternative is to clean all of the fuel out of the tank and use a low power soldering iron to melt the crack closed.
Thanks for the replies. I'll give the epoxy a shot (have a bunch of it anyways). The only hobby shop near me charges a fortune for parts (way above list) and I don't feel like paying shipping costs for just 1 item online. I'll report back on how it goes.
ORIGINAL: seagull369
Banned
I've fixed cracks by cleaning the area very well, then putting a thin layer of JBweld over it. JB weld epoxy is cheap and it holds up just fine to the fuel. It works perfectly.
CT
JB weld didnt work for me. it came right off in a solid piece.
if that was me... id say f**k it... and pull out the butane torch....
maybe in the future, ive seen RTV black silicone sealent seal tanks (my t-maxx's tank primer hole has that stuff in it from 1999)
Banned
ORIGINAL: Bluethunder3320
ORIGINAL: ZeroKelvin
One thing I should have mentioned (didn't think about it when I first posted) is that I lightly sanded the surface around the crack prior to applying the JB weld. By roughing it up, the epoxy was able to bond to very well. Mine has been on since 2 summers ago and still holding.
On a slight side-note to the OP: How exactly did the tank crack in the first place, and where?
ORIGINAL: rc awesome
Install a new tank, its not too hard
I noticed some silicone spread over the crack, applied from previous owner I guess, but it didn't hold. I pealed it off with just a fingernail.
In my experience, JB works adheres much better to metal than plastic. I also have some PVC cleaner & cement (more meant to solvent join plumbing fittings to each other) I think I'll play with on some scrap t-maxx tanks I've held on to to see if that works.
In case anyone's interested in this kind of stuff, I found an interesting adhesive online designed to work on polyethylene-type plastic (which I don't think the savage's tank is made of), which ordinarily is very difficult to repair outside of welding processes. Here's a youtube vid (this company actually has a lot of vids there showing how to work with with lots of different resins): http://www.youtube.com/watch?v=h-9yhanz5DE
Banned
I bought it second hand and it was that way when I got it (of course the guy didn't tell me that). Found out the hard way when I filled 'er up. Considering I only paid 75 for it, I'm not complaining!
CT
I would not go and buy silicone just to seal the tank.
Ive been cheap in my r/c history... Lol... Once i tried making better teeth on bevel gears with j-b.
It never worked, and i eventually spent $5 on new gears.
The one way i can ever see a crack in plastic sealing is if the two pieeces are actually melted together.
