Corona Advice
Corona Advice
I´m in the process of buying a corona for my first Heli, and I own a Futaba conquest with a receiver and two micro servos (G type connectors)
Can I use these with two adittional micro servos (J type with adapter to G) , or I must use the recomended hitecs 55 with a new receiver.
I understand Hitec and Futaba are compatible, and would like to save some money using the radio gear that I have.
Any advice is greatly appreciated.
Corona Advice
What size Futaba servos do you have? There is no electronic compatibility issue with your gear.
BTW Hitec 55's are way too small for a Corona. They are the entry level choice for Hornets and Piccolos. The popular choice for Corona servos are the Hitec HS-81's and 85's.
Also, you'll get quicker replys if you post your questions here:
http://www.rcuniverse.com/forumdispl...s=&forumid=192
Hope this helps.
Cheers - Boyd
AMA 80393
Major USAF
Retired
Hope this helps.
Cheers - Boyd
AMA 80393
Major USAF
Retired
