Need help
Need help
hi
my mini dragonfly seems to be swing from left to right and no matter how you balance it. It seems that the heli is not stable and how do i over come it. When ever you increased the throttle, it'll swing to the left and once it's up from the ground it either swing to the left or right extremely. Did try to trim it but it did help. Please advice. Thanks
Need help
Have you tried turning up the gain on the gyro? The default settings are always low.
Also, you MUST remove any rudder trim each and every time you initialise the heli. You can then add it for each flight. A pain, I know, but you get used to it!
