How to Run Pump at Max Voltage to Test Fuel System With Engine Off
Since I've had JetCat's in the past, this is easy to do with their GSU.
This procedure is what I like to do every time I have a new jet to test how robust my fuel system at it's final set up point.
How can I simulate the engine running at full throttle by running the fuel pump running at full throttle to drain my fuel tanks and check for leaks?
Thanks Barry and Dirk!
I don't think you can just run the pump at max voltage for a while to test the fuel system with xicoy at all
Will have to try it with the newer xicoy ecus then, I remember the older one would cut after reaching the maximum. Haven't actually tried with the newer one though, now that I think about it.
Ok, sorry to bring this back up. I could've sworn this worked on my previous king tech install. But when I press on on the primp pump fxn, the pump starts slowly and then constantly increases it's speed and then it just stops.
Occasionally, the screen will briefly say "overload" and then it will return to the run screen.
Any ideas?
Any ideas?
Brand new install in a brand new jet. The engine is a few years old, but with only 4 hours on it, K180G if that matters.
The engine starts and runs great! The batteries are fresh and I don't run fuel filters other than the high flow BVM UAT.
I do have a 1S lipo that was going to connect to the pump (3.7 volts) and just run the pump that way, but how can I tell if I have a bad pump?
You guys understand how important it is to check your fuel tank set up on the ground to make sure it is all bubble free!
Thank you gunradd.
Thank you gunradd.
Rav, if you looped it from a jar of fuel and still having overload, then it's probably a sticky pump, such a pump may not give you the best idle, sometimes even flaming out during deceleration. You could also try to reverse the pump with the looped jar, the idea is to "exercise" it, good luck and let us know.
Barry
Barry
Hi Barry,
Do you recommend that I don't use this pump? Should I just run it, say, 10 times in a row?
Here is a vid of what it does.
https://www.youtube.com/watch?v=lssWhrlCHTc
You may want to reestablish the pump limit by running it up to full power and take that pw value and add a 10%, chances are you may end up at around 300s, then you may have a better overall throttle resolution and probably even better idle, probably be able to solve your problem of test run pump to drain you tank.
Above is also explained in the manual under troubleshooting for rough or high idle.
Regards,
Barry
Regards,
Barry
