Phoenix Models hardware caution!
Old 06-16-2005, 09:11 PM
RV8NUT
Default Phoenix Models hardware caution!
Just a caution to anyone using the stock Phoenix Models hardware, I lost my Strega yesterday due to a failure of the elevator control horn. It snapped off at the base, leaving both base plates still attached to the elevator. It was my fourth flight of the day and was on downwind when it let go - fortunately got it pointed away from the pits before it impacted. the plane was totaled, but it could have been much worse if somebody was hit.
I had upgraded the pushrod clevises (as I usually do) and epoxied the pre-installed hinges, but this wasn't enough.
On a positive note, I was impressed enough with the plane and its build quality ( got a close-up look after the crash!)that I just ordered a new one along with some Du-Bro control horns.....
Old 06-17-2005, 05:26 AM
WB2SXN
Default RE: Phoenix Models hardware caution!
Hi RV8NUT,
Sorry for the loss of your plane - possibly the company will help you out??
Where do you obtain the clevis with the steel pin ??
appreciate any info - thanks
Bing WB2SXN
Old 06-17-2005, 07:52 AM
piper_chuck
My Feedback: (12)
piper_chuck's Avatar
You definitely should talk to the place you got it from. There have been many posts saying companies will replace the plane after this kind of failure.
Old 06-17-2005, 07:57 AM
exeter_acres
exeter_acres's Avatar
Sorry about the loss......
Old 06-17-2005, 04:16 PM
Stik-n-Rdr
Thanks for the info RV9Nut. I just completed the install of the stock horns on my Giles 202 so will see how they hold up.
Old 06-17-2005, 06:00 PM
aghost
My Feedback: (13)
aghost's Avatar
WB2SXN - There are probably other places, but Airborne Models has the clevis with steel pins. Look under their catalog and Accesories Part II.
http://www.airborne-models.com/
Brian
