Retracts needed
Retracts needed
I am looking for a complete set of retracts (tri) to handle a 15Lbs airplane of 110" span (I know its light). Old and tired but still working considered for the right price. I need the whole kit.
Thanks for the bandwidth
Tailslide
Tailslide
Retracts needed
Tailslide:
Tower Hobbies sells the B&D trike retract set for $80. This includes the air tank, hoses, and valve.
They are 5/32" wire, putting 3/16" wire on the mains isn't hard, the nose is OK at 5/32". If you are good with your landings the 5/32" will be all right on the mains also.
If you need disconnects they are additional, and you'll have to buy an air pump.
Hope this helps.
Bill.
Hope this helps.
Bill.
