Free sim R/C Desk Pilot
Hi all,
I wanted to let you know there is a new version of the flight sim R/C Desk Pilot.
It can be downloaded for free at [link=http://rcdeskpilot.com]rcdeskpilot.com[/link] and includes following features:
[ul][*] 5 animated models, including a thermal sailplane and helicopter[*] full 3D scenery[*] wind and thermals[*] pylon racing[*] birds[*] support for anaglyph 3D (red/cyan glasses)
[/ul]
The sim requires any version of Windows and of course a transmitter or joystick.
As I'm still heavily developing it, I would appreciate any feedback you have on the sim, either here or by email on [email protected]
Cheers,
Davy
[youtube]http://www.youtube.com/watch?v=EyaRBNMiPO8[/youtube]
[/ul]
Cheers,
Davy
MT
RE: Free sim R/C Desk Pilot
i just tried your sim and was very impressed. i am using an interlink elite to control but i am having trouble getting proper calibration? when i go to zero throttle the plane still has partial throttle. am i missing something?
Hi,
your controller should appear in the game controller section of the Windows Control Panel. You should be able to calibrate it there.
Hope this helps,
Davy
Hope this helps,
Davy
MT
ok thanks i will check that out.
hey davy check out my website http://thegibson.jimdo.com/i make 3d models of planes and would let you have some for your sim if you likeon
on edit: heres a direct link to the planes i made http://thegibson.jimdo.com/g4-5-planes/
Wow! Those are really impressive! The next big thing on my todo list is to support add-on aircraft and scenery, and I would be delighted if you decide to (let someone) convert your planes to R/C Desk Pilot.
Davy
Davy
Looking at your web site great views. Does the controller I've got a Spektrum DX7 with a USB cord (same as JR) -does this work on your system ? Thanks Bill Reid
ORIGINAL: N5502B
yes, your USB cable will make the transmitter behave like a normal joystick so it will work with R/C desk pilot.
If you can't get the trim right, calibrate it using the Windows Control Panel, Game Controllers.
Cheers,
Davy
Hello!
I purchased a cheap 4 channel USB Tx for use with RC flight simulators, and it works great with this simulator.
The setup was much easier then FMS; I only had to reverse the aileron channel. I like the menu system, It is very professional and easy to use.
The model selection is good too, for a recent release, and the moving control surfaces and props are great! It is nice to see a freeware sim with so many features - even Realflight does not have birds (fantastic work on that bit!)
Would it be possible to add a aircraft modification page as well, so users can change rates, CG, etc?
Overall, it is the most feature rich freeware sim out there! Keep up the great work, and I am looking forward to some addon aircraft and fields!
Graeme<br type="_moz"/>
ORIGINAL: GraemeEllis
Hello!
Graeme<br type=''_moz''/>
Hello!
I'm working on a aircraft editor hoping that artists like thegibson build and tweak aircraft for R/C Desk Pilot.
Cheers,
Davy
I just noticed that the wings bump around while taxiing the model on the ground!
That and the moving control surfaces - add some more models and fields, and you have essentially got Realflight!
Fantastic!
Fantastic!
NV
Hi there. We tried to install the R/C Desk pilot sim but we can't seemto get the DirectX part to run correctly. It installed ok with noerrors but it blows up as soon as you start the software up. Also the.NET framework 2.0 would not install due to incompatibility with anearlier version of .NET. We are not sure if we need to contactMicrosoft or if someone here has any idea how to troubleshoot this orat least know what to look at in their knowledge base. We are notreally familiar with how .NET and DirectX work.
ORIGINAL: rcultimatetoys
the problem is probably the fact that .NET isn't installed properly. Check this [link=http://support.microsoft.com/kb/908077]http://support.microsoft.com/kb/908077[/link] for some help with that.
After you've got .NET 2.0 installed, make sure to reinstall DirectX 9 from the [link=http://www.microsoft.com/downloads/details.aspx?FamilyID=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en]Microsoft site[/link] or let the sim installer install it. It is important to install DirectX after .NET because it will add some libraries to the existing .NET installation.
I hope you can get it to work. If not, can you post some more details about the errors you're seeing (and the OS you're working with)?
Cheers,
Davy
Hi everybody,
a short update on the sim: I've been working on the aircraft editor for the last couple of months and it's almost finished. So I thought I would share a short [link=http://rcdeskpilot.com/node/27]preview[/link] (you'll have to put up with my Belgian accent though)
[youtube]http://www.youtube.com/watch?v=nHy73xujk3A[/youtube]
I'll put it up for beta in a couple of weeks. I hope I can convince some of the talent here to start using it
Cheers,
Davy
Cheers,
Davy
ORIGINAL: rc airplane nut
New (or more) planes too?
Davy
OH
First of all your Simulator is great. I have a Dynam transmitter which came with FMS simulator and it don,t work withWindows 7. I wish your web page had itsown Forums.
Thanks Jack
Thanks Jack
Thank you, Davy; yours is awesome work.
I downloaded it today, and enjoyed it much.
However; I had to use the keys, which were way too sensitive for the Extra, especially the elevator key.
For some reason, my Futaba Tx did not work with the same cable it works with for FMS.
Any suggestions?
Again, thanks!
Any suggestions?
Again, thanks!
ORIGINAL: LNEWQBAN
Any suggestions?
Again, thanks!
Any suggestions?
Again, thanks!
does your controller appear in the game controller list in the Windows Control Panel (the exact location depends on your Windows version)? The sim works with joystick compatible controllers/cables. If it does, try calibrating it in the Control Panel. If not, you are probably using a serial or audio cable. In that case you'll need to install and config PICjoy (serial cable) or SmartPropoPlus (audio cable) and PPJoy. A nice explanation of these can be found [link=http://sim.tomsrc.com/page.php?17]here[/link]. These will emulate a joystick in Windows. Most USB cables will be recognized as joysticks from the start so should work after calibrating in Windows and configuring the controls in the sim.
Hope this helps,
Davy
I D/L your program and installed it on 64 bit Windows 7. It works GREAT !!! You have done a fantastic job of programming with this.
I am using a RealFlight G2 controller hooked up to a serial to USB converter. Once I configured the controller in Windows I was able to set it up in the program.
A couple things I did notice:
1. The throttle and rudder will only work on channel 6 & 7. The program will not allow me to change it to channel 3 & 4.
Right now this is OK, however, this may be a problem when you launch your "new" model with retracts [and I presume] flaps.
2. A windsock near the runway would be a big help in setting up the direction and force of the wind in the weather section.
I am not "picking" - you did ask for feedback.
