binding 1221x receivers
My Feedback: (7)
WA
I have 2 NIB 1221x receivers and neither of them will go into bind mode. I have all 3 satellites plugged in with a battery plugged directly into the batt port and bind plug in the bind port. When I plug in the batt the bind light flickers and goes out, it will not come on and flash like it was ready to bind. Am I doing something wrong?
With the 1221 it is easy to mistake which slot is the bind port or insert the battery plug wrong. I have a JR R1221 DSM2 receiver and the case should be the same as yours. With the JR label up and looking at the connector end, the bind port is the far-right vertical slot on the bottom row. The battery slots are on the top row of horizontal slots. The battery plug is inserted upside down, i.e., the plug visible contacts face downward.
Allan
Allan
