Viriations of mixture between upright and inverted
My favorite plane has a 35cc mounted inverted. All is fine except the variation of mixture between upright and inverted flight. The carb as mounted has the metering circuit plate down. It is a rear carb engine running a Vess 20A about 7500. It starts easily cold or warm, transitions fine, makes plenty of power and has never dead sticked.
During inverted flight, it runs rich. Low speed needle is as lean as it will go without compromising transition. High speed needle is adjusted until no more gain in rpm. The HS needle is not as sensitive as most gas engines.
My thinking is that the metering circuit is where to look. That gravity weight of the metering diaphragm though subtle, is just enough to cause the mixture differences. That while upright, the metering needle has a hair more closure tension than it does inverted.
Does this make any sense? Any one else experience similar? Is a fix to adjust the metering arm?
RE: Viriations of mixture between upright and inverted
Get another spring; then stretch the one in the carb. See what effect that action has. If it messes things up you can replace the spring. Beats bending the lever.
CR
CR
I think there is some agreement that the metering circuit is suspect and the suggestion to use another spring stretched slightly is good advice... I'll give it a try.
If the cowl could cause a different atmospheric reference between upright and inverted, removing it for a test might be helpful but I can't imagine how it could do that. If it were not ventilated properly it could cause variations of mixture at various engine rpms, but that is a much different thing than the issue at hand.
My Feedback: (7)
AR
Interesting read. Let us know if the metering spring works. I have very similar problem...only it is reverse of yours, but same symptoms. By the way I flew mine with and without cowl and it didn't change either way.
My Feedback: (7)
AR
ORIGINAL: WRK
Do you have a vent line from the carb. to the canopy or something equivalent?
My Feedback: (7)
AR
ORIGINAL: Tony Hallo
Some random thoughts. Can you rotate the carb 90 degrees? or is it possible you have a puddling problem?
Try something like flying inverted for more testing. Fly long lines while climbing and long lines slightly diving. Try some big inverted 8,s....see what this does to engine sound of going rich. Is you fuel tank mounted real low in airplane? I could see where a high angle of attack when inverted could cause a real different airflow over cowl also.
Capt,n
Capt,n
ORIGINAL: w8ye
You need a higher pop off pressure in your metering circuit so gravity has less effect on it.
The problem is more commonly seen on engines mounted with the cylinder upwards, and running rich in the midrange. Fuel accumulates in the crankcase while cruising around upright, and when you go inverted, the accumulated fuel enters the mix and it goes rich. However, there is still the possibility at least that there is some kind of an air flow difference in your case between upright and inverted that is causing the mixture difference for one reason or another. Flying without the cowl might address this....
AV8TOR
Hi AV8TOR, we are now in Aripeka Florda at a RV Park. I did bring one airplane too fly & engines to work on. I know 2 guys from near home. One flyer & one fisherman....and I have not had a chance to do either. Good too rest after a long drive & getting things in place + washing the RV ect. Best Regards, Capt,n
ORIGINAL: texasporty
Not impossible...but would require machining or making the pulse line external. I do believe the effect would be opposite.
Hopefully you can visit this link and do some more reading.
Most people including myself should never "tune" a gas engine that was previously running well,have you filtered your fuel well and cleaned your screens??
www.flyinggiants.com/forums/showthread.php
err.. I need a technology primer here. Am fairly new to gas and only exposed to a dle20. I did notice that fuel wud pour out of the vent when the airplane was held nose down but nothing much else
ameyam
ameyam
ORIGINAL: ameyam
err.. I need a technology primer here. Am fairly new to gas and only exposed to a dle20. I did notice that <u>fuel wud pour out of the vent when the airplane was held nose down</u> but nothing much else
ameyam
ameyam
