Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Condor Hobbies
Battery charger, good or bad?
Condor Hobbies Click here to find information and help from the guys at Condor Hobbies.
Old 06-15-2014, 02:21 PM
rotee6977
Default Battery charger, good or bad?
I bought this 1:6 hummer and went to charge battery and the light on charger doesnt come on but it gets hot while charging, do you think it is working?
jnayjaso (04-05-2020)
Old 06-15-2014, 08:35 PM
chuckk2
The information you gave is less than needed to form an opinion.
That aside, I'd say get a "real" charger. 1:6 Hummer ?????
Old 06-16-2014, 02:03 PM
rotee6977
Sorry, I bought a scale 1:6 hummer and it came with a battery and charger. I plugged in battery to charger and there is a light on charger but it does not come on when plugged in but the charger itself gets warm so i was wondering if it is working and the battery is bad? Or if the charger is good and i have a bad battery or if the battery is good and i need a new charger. Thanks for any help you can offer.
Old 07-03-2014, 02:20 AM
chuckk2
The problem you have is typical of the low end came in the box chargers. Some sort of battery checker, such as a DVM or more specialized tester
is needed to check the battery when you suspect problems.
I have no idea what the light is supposed to show. (Power On? Battery Charged? Fault?)
You also didn't say what the battery type is. Lipo? NiCad? NMIH?
Each type uses a different charging scheme, with the Lipo being the most particular.
Old 10-30-2014, 09:33 PM
Cynthia23
Cynthia23's Avatar
I have a lipo battery with a similar problem.. It charges okay and the light on the charger also comes on but it becomes so very hot while charging. Don't know what the problem is..
Old 11-12-2014, 07:16 PM
chuckk2
Since the lipo works, it's rather obvious that the charger is the problem. There are many cheap chargers supplied with RTF planes and cars that are not really
what is needed to charge lipos.
Old 01-04-2015, 11:42 PM
Tommy91
don't use cheap charger. A good charger lengthen your battery life.
Old 01-21-2015, 03:40 AM
Kipp Louis
you need very careful about this. I personally use the balance charging option when preparing the batts the day before going to run.
Old 10-13-2019, 01:10 AM
architfly
you always need to take utmost care.
Old 04-21-2020, 07:49 PM
Ameat1993
It is depend on size and quality regard batteries and hummer. You can check how much power to hummer for its performance.
