Bandit ARF MK I
Bandit ARF MK I
Old 04-05-2023, 06:39 PM
c/f
Default Bandit ARF MK I
I just scored a NIB Bandit ARF MKI is my guess from my researching. Not positive though. It came with everything BVM purple and JR Servos. Is there a sure way to know which version?
It has the BVM serial numbers is my last resort call in to BVM.
I will be powering it with a Xicoy X120 Lite. Any words of wisdom or best relevant link would be appreciated.
Old 04-06-2023, 04:57 AM
turbomike
My Feedback: (9)
Does it have a hatch in the bottom of the fuse?
Old 04-07-2023, 04:39 AM
c/f
Yes it does, I'm guessing that was removed in MK II?
Old 04-07-2023, 07:22 AM
Ron S
Ron S's Avatar
I have a Mk I, (I guess you'd call it.) You need the lower square hatch to access the 10 or so cap screws to install the wings. The Mk I uses carbon fiber blade spars, essentially.
The Mk II uses an aluminum tube, I believe, as the wing spar. Because of that, they can get away without needing the big hatch on the bottom for wing installation.
Old 04-07-2023, 03:16 PM
DAN AVILLA
My Feedback: (12)
DAN AVILLA's Avatar
That is great plane. I have had many. Use BVM's 15% take off and 45% on the flaps. I would take BVM's control throughs and start with 75% of what they say for high. Use their CG. I always had about 8MM of crow for landing. Dan Avilla
Old 04-07-2023, 06:35 PM
F900
I also have a Mk1 not flown yet, hoping the flight it soon, it's so light I have powered it with a SW80
Old 04-07-2023, 10:36 PM
bandit_av
Hi....
I had one like this for over 22 years, and now after I lost it, I bought one like this relatively new that needs to be finished building. The plane is one of the most wonderful I have ever flown, including all sport jets of all kinds. Pay attention to the issue of the engine, at first I had the AMT MERCURY HP with about 9.5 kg thrust, and then I changed it to a Merlin 120, with a thrust and weight pretty much the same as yours, which resulted in a weight reduction of about 800 grams from 9.7 kg, to about 8.9-9 Kg, and on the other hand, a significant increase in thrust, and believe me, a ballistic missile was created here, which I think is too much. In my new one, which is towards the end of construction, I might limit the engine a bit to 10-11 kg, but I haven't made a decision yet... just seeing this rocket was exciting...By the way, in continuation of what was said before, you will use the CG point that BVM recommends, there is simply no need to change.
I didn't use the first one with a gyro, because I just don't need it! But in my current one, I'll install it, just for the fun.
And more... I replaced and converted all the air systems in the wheels and doors to electric ones, and completely changed the whole mechanism of the doors in the wings, because it was always a headache, and a source of problems all the time. That way each wing has an electric door, saving myself quite a bit of trouble' and you not need all the time to connect and disconnect the doors with the air pistons.
Avi
Old 04-08-2023, 10:27 AM
F900
Any tips on attaching the wings? since every time you have to remove the bottom panel and turn it upside down which I dislike.
Old 04-08-2023, 01:08 PM
DAN AVILLA
My Feedback: (12)
DAN AVILLA's Avatar
I purchased a right angle cordless drill attachment and tool a extra ball wrench and cut it off and welded it to a apex. I put them in by hand then tightn with the drill. Dan
Old 04-08-2023, 01:46 PM
jsnipes
Buy a trailer and eliminate the need to remove wings! LOL!
Joking aside, awesome find! Nothing flies better than a BVM Bandit … regardless of which version. I had a MkII with a 120N turbine in it and I wouldn’t want one any other way after flying it. The 100N was just kinda meh …I do not know the weight difference of the MkI vs II though.
I always find BVM cg settings to be conservative and end up moving them back as I fly it/tune it.. Maybe the MkI is different from the MKII in this respect.
Highly recommend a Cortex Pro gyro. It’s not a matter of needing it … every rc plane is affected by wind and why fight it when there is proven technology to counter the buffeting of the wind to have that “locked in” feeling? To each their own, though.
Keep us posted on the build and enjoy!
JS
Old 04-09-2023, 12:09 AM
bandit_av
JS
Following on from what you mentioned about the 120N thrust, I really agree with you, as I mentioned, it's a crazy ballistic missile, and even after over 45 years of flying, it's really exciting, even though I had some thoughts that it was a bit too much.
Regarding the gyro, I didn't use my previous one, but I will use the new one with the PB iGyro3xtra, it can only add to the already super accurate platform.
Avi
jsnipes (04-12-2023)
Old 04-11-2023, 04:35 AM
stealdesk
I have a Classic Composite T Bandit (Mk 1?). I fly it with a Swiwin 120 and it is very fast.
The following 2 users liked this post by stealdesk:
Auburn02 (04-11-2023), Ron S (04-11-2023)
Old 04-11-2023, 06:14 AM
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Ludicrous speed more like lol
The following 2 users liked this post by yeahbaby:
Hnorth (04-11-2023), jsnipes (04-12-2023)
Old 09-12-2024, 09:44 PM
samdimaio
My Feedback: (106)
Attachment 2272680
Any interest in selling your orange and white Bandit ARF? Sam DiMaio 484-401-6990.
Old 09-14-2024, 09:16 PM
DUCMOZ
Bandit Arf mark 1, has two little holes on the bottom which are the CG markings. Please remember that a few years ago BVM updated and I believe the new correct CG is about 20mm behind the holes.
Behzad
David J Ruskin (09-15-2024)
Old 09-15-2024, 09:30 AM
DAN AVILLA
My Feedback: (12)
DAN AVILLA's Avatar
BVM has all the old settings on their site. All are 9.25 back at leading edge measured at the root. Dan
