Picco .21 hot idle problem
I have the Werks Racing Picco .21 on my Maxx. It runs great when cold and for the first five minutes or so until it gets up to the 250-260deg range. Then the idle hangs very high when letting off the throttle and it gets a serious midrange BOG.
THis only occurs when it is hot. The fuel tank O-ring is kinda beat up so I am replacing it just in case, but I am not convinced that that is the problem.
Any Ideas????????
Any Ideas????????
RE: Picco .21 hot idle problem
may be a low speed needle but not sure i have just replaced my carb as i had a leaky low speed needle and i couldnt get a real nice crisp tune but i have stripped it down and rebuilt the whole truck so i will post back on if it was that that was the problem
