traxxas trouble again
ok, here we go again, my electric 'pede has melted the connection plugs to the battery. I will have to replace them, should i get "no loss connecters", or just replace the old ones? I have 1500 batteries, the stock electronic speed control, and a "monsters of touring" motor. What caused them to melt? THANKS
sorry bout the spellin
PowerPole Plugs
Everyone I know laughs at me, but I love these plugs. I use them for everything. They are "unisex" so they can be put into various configuations (no pun intended). I can use a single pack, 2 in parallel, or 2 in series with no problem. I also don't have to stop and think about whether I should use a male or female here or there because every piece fits every other piece, and they are cheap ($1.50/pair at my LHS), and no soldering required.
--Bob
--Bob
re: $.02 on High end plugs...
From a friend at a hobby shop who sold Deans plugs... he thought that at $2 a pop, $$ of wiring and the time to install, he didn't think they were worth it...
"Deans plugs matter if you're racing, or have some kind exotic motor/esc that draw's a ton of amps. Other than those situations, for the cost, basic Tamiya plug is your best bet. The most you'll notice between them is a couple percent gain in performance and run time."
Off Roader
Off Roader
Dean's are nice plugs, and I've used them; but for the price and convenience I'd have to stick with the PowerPoles. I climb rocks and chase dogs in the parks and my plugs have never come loose or gotten hot regardless of how hard I crashed or how hot my batteries and motor became. If you have the money and time, go Dean's. If your funds are limited (I'm a high school teacher), try the PowerPoles.
Listen to the wise Elwood my friend..... Use Deans Plugs for EVERYTHING!! How can you argue when they have less resistance than the same length of wire?? GET THE DEANS!
Questions....
The reason your connector is melting is two fold... Too much current and/or too much resistance. The combination of these two = heat.
Does the battery get really hot when running? It may be heating up the wires which in turn heats up the plug. If so, you have a bad battery, not a bad plug.
What's your wiring look like? What guage? New, old?
Are the connectors you were using new? Used? How good was the solder joint? BTW, the bigger the blob, the better the job solder joints aren't the way to solder them.
These all contribute to the melt down. Check them first. You may find that the cause is elsewhere, rather than pay to upgrade everything to a high end plug setup and still have things too hot.
$.02
$.02
the speed control is stock electric and the batteries are duratrax 1500s. The batteries are usually not hot but the speed control is. i just shelfed it for now, i'm having too much fun with my mini-z!
Hot Speed Controller is not good...
In fact, it may also melt the new connectors, or worse, burn up your ESC.
Not personally familiar with that ESC, but I run dual 19 turn Trinity Speed Gem motors (stock is a 27T mabuchi) with 20 Tooth pinions (stock is 18) on a single Dynamite Power Pulse speed controller and after running a 3000 mAH battery, the ESC is just starting to get warm along with the wiring. After running all my batteries (2x3000 mAH, 2x 1500 mAH, 2x unknown mAH) one after another with no pauses other than to change them, the controller and wires are much warmer but you can still touch them for about 10 sec's before it gets uncomfortable.
That's after over an hour of hard running.
Keep in mind that the Power Pulse isn't exactly a high end ESC... more like entry level... heck at $60 retail, its relatively cheap.
I'd contact your ESC maker and ask if it's designed to handle those motors.
