limited edition, 19t clutch/ 47t spur
19t clutch be and 47 t spur gear..This combo comes with the Ltd. edition with dirt bonz tires (40% lighter) and man is it fast on pavement... the question is can i drive this thing on grass or will it damage the drive train? I drive mainly on pavement driving the neighbors nutz and chasing cars! but occasionaly drive it along the ditch / dirt area next to the road.. should I change it back to the 15 tooth bell ? But man i love speed! What should I watch for? The biggest pain was adjusting 2nd gear ( required disassembling the trans)... thanks!
My Feedback: (9)
RE: limited edition, 19t clutch/ 47t spur
I'm sorry I don't have an answer, I have a question.
Before you changed clutchbells, did you have a problem with the motor sounding strained in third gear? [sm=confused.gif] When my LE hits 3rd, there is no power or speed increase and the motor sounds like it is completely wound out. Does that sound familiar at all?
This situation is only true for third gear with my truck. []
you mean like a strange "sputter" kind of sound? yeah mine did that and I tried tuning till I was blue in the face but once i changed the gearing ( clutch ) it no longer makes the noise..
My Feedback: (9)
what combo you runnin?
Come to think of it, I did not even bother to look at the extra spur gear that came with the truck. [] I bet it should be used with the 19 tooth clutchbell, huh?
...............maybe tomorrow.
That's really tall gearing for anything other than pavement. If you have a temp gun, monitor your clutch bell temps. If they approach 200F you're in danger of melting a spur.
How are your dirt bonz holding up to the pavement? I've only run mine on dirt and grass.
The only thing to worry about running that tall of gearing is clutch slippage and CB temps as noted above. Dump the plastic clutch shoes for some aluminum shoes (Mugens work best) and the only thing you will have to worry about will be poor acceleration. I ran 18/47 with my SH and proline bowties (Non 40 Series) and it was a high speed wheelie machine.
My Feedback: (9)
I will definitely get the aluminum clutch shoes and a 17 tooth clutchbell. I'm just not satisfied with the 15T or the 19T. Maybe the 17T will give me what I want from both top end and low end. [8D]
The mugem cluth shoes help a lot. ive broken in my le on pavement with my s25 and the traed still look brand new. now with my 32, there is no way i'm going on pavement. how fast do u think my savvy is going. a stock le with a collari 32 and mugen aluminum clutch shoes. like 40 u think becuz it looks crazy fast on loose dirt.
