Over Heating problem
Hello,
I have a Sig Cap 231EX that I am having a little over heating problem with after I put the Cowl on.
My SETUP is...a MOKI 1.35 (with about 4 hours of break in) and I have a Bisson pits muffler on it with about a 3.5" X 8.5" exit cut in the cowl.
Could someone show me a good way to put a Baffle in so as not to have anymore trouble I real want to put the cowl on.
Thanks, Robin
Thanks, Robin
My Feedback: (80)
MI
Robin,
Can't help you with the baffle. Sounds like you have more than enough exit to intake ratio. What type of fuel are you running? I flew a Moki 2.10 on Byron FAI fuel with no problems. Some of the larger glows don't like the nitro if thats what your using. Just a thought.
Chook,
I am running FAI Fuel NO Nitro and 5/32 ID line. I have a 24 OZ. tank in it and I set the high end with about 1/8th tank of fuel in it.
Runs real strong and very reliable with out the cowl...lol soon as I put it on, it over heats, I do not want to ruin this engine, but I really want to put this cowl on.
Robin
Robin
Moki Overheating
If you have opened up both intakes on the front of the cowl that could be a problem, I only open up the one in front of the cylinder and leave the otherone blocked off. My 2.10 in a edge gave me problems until I blocked off the one side. { I assume that the motor is mounted side ways }. This allows air to only enter and go accross the engine, if you open up the other side all the air will go through it and not over the engine.
